1992 Cilica will not start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2005, 02:09 PM   #1 (permalink)
Gil
View Gil's Photo Gallery
Unhappy 1992 Cilica will not start
I bought this car 2 months ago and it was having some kind of problem starting. As I turned the key it would make a "click" sound but would not start. After 10 - 15 times turning the key it would start. Then one day it quit making the "click" sound and now it will not start at all, that is with me turning the key. I can start it by rolling it down my slopped drive way with no problem. My cousin told me to remove the stater and replace the brass terminal where the cable coming from the battery is connected, so I did. It still will not start. I checked the small connector on the starter for 12v while pressing on the clutch, while turning the key and without doing anything and there is no voltage. There is also no 12v on the prongs where my starter relay goes (passenger side fuse box).
Any Ideas.
TIA
Gilbert
Gil is offline   Reply With Quote
Old 01-05-2005, 05:09 PM   #2 (permalink)
Boooost
turbo_GT's Avatar
View turbo_GT's Photo Gallery
u need a new battery...
Your signature is in violation of rule #4.
http://www.toyotanation.com/forum/t20118.html
turbo_GT is offline   Reply With Quote
Old 01-06-2005, 03:43 AM   #3 (permalink)
Scoobie Killer
View Insanity-74's Photo Gallery
I agree....the click sound you hear is the solenoid that engages the starter motor and dosnt require much power, but there is insuficient power to crank the engine, also remember that when you buy a new battery to charge it up over night cause if the battery has been sat in the shop for a while it will have lost some of its charge and you dont want to warp the plates in a brand new battery by over stressing it.
Living the dream
Insanity-74 is offline   Reply With Quote
Old 04-09-2005, 05:17 PM   #4 (permalink)
View andrew15381's Photo Gallery
yep new battery! i just had that problem! bought battery! problem solved!
andrew15381 is offline   Reply With Quote
Old 05-02-2005, 06:43 PM   #5 (permalink)
View CelicaGuy13's Photo Gallery
Just had that plm today. what happened was that my battery was leaking and got onto the wireharness or wires to the starter. So when i washed the car.. it melted the harness or wires not sure. the guy just cleaned up the wires to the battery posts, and i guess he fixed some wires. that solved it though.
CelicaGuy13 is offline   Reply With Quote
Old 05-18-2005, 11:38 PM   #6 (permalink)
View Jamie Moore's Photo Gallery
I've had the same problem for 2+ years. Starter messed up Changed it fixed problem for 6-+ months back to the same click for about 1.5 years.cheap advance auto starter.
Jamie Moore is offline   Reply With Quote
Old 05-19-2005, 10:37 AM   #7 (permalink)
All it takes is MONEY
View marcuslogsdon's Photo Gallery
yea sometimes the solenoid contacts arc and basicily melt the contact away. so your clicking could be the solenoid trying to make contact but not transfering the current!!!! always check battery open post voltage before replacing!!!
marcuslogsdon is offline   Reply With Quote
