If you have bought stiffer/shorter springs (Eibach, H&R etc) regular shocks wont last long so you would need a high performance shock that would deal with the shorter/stiffer spring rate, Having said that:
KYBs GR2: wont last on shorter springs, (these are Toyota OEM for the NADM)
Tokicos: Same as above althought they will last longer since they are better quality than the KYB GR2 (these are Toyota OEM in Europe, South America and maybe Japan)
Bilstein: I installed a set of Bilstein last November but since the car has been on the fritz I have yet to see how much will they last but they have far better quality than the previous.
If money is no objection and you want top notch handling then you should get a set of Koni Sports (Yellow colored ones). These are the best shocks for ANY car, pricey? yes but they are REALLY WORTH IT right down to the last penny.
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
