There are about ten different types of coolant available, the basic difference, apart from the colour, is their anti corosion ability, freezing/boiling temps and of course who makes it. Most are compatable with no ill effects but I believe that the Blue/green coolant is not compatable with 2 of Toyotas coolants (pink and red), Toyota have three different colours that I know of depending on what year the car was manufactured (the other being blue/green)
In 1994 Toyota Celicas used the red coolant
If you mix the two it can do things like corrode the rubber pipes etc (a long term effect) Your best bet would be to undo the drain plug and let all the old coolant out, the flush the system using regular water (i used a hosepipe stuck into one of the heater matrix pipes that passes into the bulkhead - be carefull not to confuse it with the aircon pipes). Once youe have flushed the system, reconnect evrything and fill up with the correct RED fluid, ready mixed from Toyota dealers use the bleed valves if you have any, then run the engine, this will pump the fluid round and hopefully get rid of any airgaps, top up as necessary.
Living the dream
