All trac/GT-S suspension diff? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2005, 01:19 PM   #1 (permalink)
View TRDcelicaGTFOUR's Photo Gallery
Whats the difference between the all trac and GT-S suspension? Can I put my current lowering application on a alltrac? The Koni Yellows I know will fit, but the Eibachs, Im not sure if they will go. Are the two model celicas equipped with the same springs, or is there a big difference. If not, what are some possible springs that will go on the alltrac?
Thanx in advance.
FS: 17" ADR Ryver w/Firestone Firehawks 235/45ZR17
MOMO Shift knob/ ebrake w/boots
TRDcelicaGTFOUR is offline   Reply With Quote
Old 01-21-2005, 01:35 PM   #2 (permalink)
Immortal
View Kwanza's Photo Gallery
I believe 4th and 5th gen Models are all the same, GT/GTS and Alltrac. The spring rates on the stock springs are probably different because of weight, but I'm pretty sure the actual springs are pretty much the same.
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 01-21-2005, 02:47 PM   #3 (permalink)
Gameroom cash: $147537
Go to eibach website and check part number.
Old 01-21-2005, 05:11 PM   #4 (permalink)
Boooost
turbo_GT's Avatar
View turbo_GT's Photo Gallery
No, the spring rates for alltracs are different compare to the GT/GTS. The alltracs are heavier than the GT/GTS so they made it stiffer. If it were to use the same spring rates, the alltracs would be dropped do the ground. It wouldn't be so good, it would probably feel more like stock.
Your signature is in violation of rule #4.
http://www.toyotanation.com/forum/t20118.html
turbo_GT is offline   Reply With Quote
Old 01-22-2005, 05:04 PM   #5 (permalink)
Thanx for the info guys. Just to expand on the different springs, I have Eibach Sportlines on my GT-S. Will these springs, on Koni Yellows give a good ride on an alltrac? I know that they will fit, and realize that the alltrac is only a couple of hundred pounds heavier. So my question is, how good of a ride will an alltrac have with the Eibachs on Konis? Thanx a lot for your help.
