Engine Tapping On Start Up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2005, 12:55 PM   #1 (permalink)
View IGGY545's Photo Gallery
I Have A Celica 2.0 Gt M Reg Car Which Has Just Had A New Engine Fitted, On Initial Start-up I Get A Tapping Sound Like All The Oil Has Drained Out The Tappets And The Cam Is Not Getting Lubricated. After About 20 Sec It Runs Fine As It Should, And With No Tapping And No Problems Like This All Day Starting It Again. Does Any1 Know Whether This Is Normal For New Toyota Engines Because I Have Heard That The Engines Are Noise On Initial Starup. I Would Appreciate Any 1 Who Could Help Or Has Had This Problem Themselves.
IGGY545 is offline   Reply With Quote
Old 01-23-2005, 08:00 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
dont buy cheap oil filters, get the ones with the silicone valve to keep the oil filter filled up over nite
Old 01-23-2005, 10:24 PM   #3 (permalink)
View rellik's Photo Gallery
I agree.
Oil travels from the pump to the filter, then to the many oil gallyes to do its job.
Must good filters have a valve to prevent oil from traveling out of the filter and back into the crankcase after the engine is shut off( and keep the oil in the gallye from the pump to the filter). This means that oil is in the gallyes and ready for use as soon as the engine is cranked over...no dry start.
Or it could mean that your valves are not at the right ajustment
I would start with the filter and correct oil.
Rellik
rellik is offline   Reply With Quote
Old 01-24-2005, 05:38 AM   #4 (permalink)
Thanks For That I Will Give It A Try Cheers
Old 01-27-2005, 06:07 AM   #5 (permalink)
Changed The Oil and Filter But The Tapping Is Still There. How Hardis It To Set The Valves Up On This Engine
Old 01-27-2005, 01:07 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
its not the valves, they are s0olid lifter type set with shims, what year and motor do you have?
Old 01-29-2005, 07:32 PM   #7 (permalink)
It 1994 Model. I Also Think It May Be The Hydralic Tappets But Not Really Sure.
Old 01-29-2005, 08:56 PM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
a 2.0 gt, what motor is it?
Old 01-30-2005, 11:15 AM   #9 (permalink)
Yeah Mate 2.0 Gt
Old 01-30-2005, 11:59 AM   #10 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
great, look on one of the stickers on the underside of the hood or on the belt end of the motor, look for 3sfe or 3sge
Old 01-30-2005, 12:49 PM   #11 (permalink)
3sge
Old 01-30-2005, 01:05 PM   #12 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
Ok, the ge head has solid shim type bucket lifters, unless there is too much clearance above the shim from wear, it usually isnt a problem, the valvetrain doesnt need oil to do anything but lubricate it. Now, the ge pistons are kindof a loose fit in the bore and have been known to make noises when cold, what year is this ge motor?
Old 01-30-2005, 01:22 PM   #13 (permalink)
the engine was supplied & fitted as a low mileage unit dont know year of manufacture
Old 01-30-2005, 06:00 PM   #14 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
its probably a gen 2 or 3, the gen1 has just 2 cam covers and the later ones have a full cover for the head
Old 01-30-2005, 06:00 PM   #15 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
put a pic of it on here
