Help with probs
hey i've got a 1994 celica gt which has the 2.2L in it. the st (your model) has a few minor differences like the taillights and rear end but other than the engine and that, its about the same car as the gt. On you power steering leak, check both the return and send power steering fluid lines. thats where mine leaked when i bought it. try checking your spark plugs, ignition coils, spark plug wires, etc to see if you can find the problem with your car bogging down. also like a few other ppl said, the celica is prone to over fueling which actually loses power and in the severity of your case can kill the engine. also check your fuel lines, pump injectors and filter, try buying some fuel injector/fuel system treatment and cleaner, i did this to mine and it not only ran better, it was a little smoother acceleration. hope this helps!
