83 Celica GT-I hate my rear-end - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2005, 06:28 PM   #1 (permalink)
View Tomonzo's Photo Gallery
Question 83 Celica GT-I hate my rear-end
Does anyone know if you can swap the rear end out of a 85 supra to a 83 celica? I dont like the solid rear, i want independent suspention!!!!!!
Tomonzo is offline   Reply With Quote
Old 01-26-2005, 06:29 PM   #2 (permalink)
i also want to put the trany in too, will it all just bolt in or will i have to fab it?
Old 01-27-2005, 06:14 AM   #3 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
It can be done but there is so much that you would have to do that it is not even worth it. Why is it you hate your solid rear end? I have an 81 Celica so it is a solid rear end and it is great. If you want a Celica and IRS then your only option is to find an 84-85 Celica GTS because those came in IRS but other then that you are pretty much stuck with a solid rear end which isn't bad though.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 01-27-2005, 12:54 PM   #4 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Anything is possible. It's just the cost and amount of work that is needed is an issue.
http://www.xclusive.bz
Old 01-27-2005, 06:01 PM   #5 (permalink)
what about a LSD solid rear?
Old 01-27-2005, 07:07 PM   #6 (permalink)
So can i just bolt THAT rear end into my car? or will i still have to fab it?
Old 01-27-2005, 09:53 PM   #7 (permalink)
SCCA Tech Services
The Corolla AE86 GTS came with an LSD stock and they use the same rear end as all Toyota celicas with a solid rear end so you can use that. That is what I am using on my 81 Celica. Also since a lot of cars use the same rear end there are a ton of options for ring and pinion size. The 4.3 is what most GTS corollas came with. I am running a 3.9:1 ring and pinion from a 1st gen celica auto tranny.
Brian Harmer
Old 02-06-2005, 02:55 PM   #8 (permalink)
View surplusteve98's Photo Gallery
in our race car we run a 7.5" out of a 83' supra they are much stronger and the 7.5" r&p from the pickups give you alot of ratios to choose from.
surplusteve98 is offline   Reply With Quote
