86-89 Mass air flow sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2005, 10:34 PM   #1 (permalink)
View MIGHTY's Photo Gallery
I have a pondering Q , does any on know how to byepass the mass air flow, i purchased one from the junk yard and ripped it apart but could not figure out how to byepass it?????
MIGHTY is offline   Reply With Quote
Old 01-27-2005, 12:35 AM   #2 (permalink)
WRS
YO MAMA!!
View WRS's Photo Gallery
3s-fe or 3s-ge? i'm not sure on an FE but on a GE you could switch the ECU and wiring w/5th gen ECU to switch to a MAP sensor. if you want more info you could also check out www.4gcelica.net, its a site completely for 4th gen celicas.
If Nissan Motorsports = NISMO then wouldn't Honda Motorsports = HOMO?
WRS is offline   Reply With Quote
Old 01-27-2005, 07:39 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
you just cant bypass it, why do you want to do this?
Old 01-28-2005, 02:26 PM   #4 (permalink)
nice wrs thanks for the intell, i didnt know u could switch with gen 5 ecu!!!
Old 01-28-2005, 02:34 PM   #5 (permalink)
cause the mass air flow sensor has asquare that is 2.5 by 3 inches and it is a huge piece of metal that needs to be removed to get more air into the intake, like the new celicas have a sensor that fits on the side of a round tube, mine has 2 doors it has to pass threw and that is restricting my air flow even w/ a super chager. it goes from this"0"to"[]"to"0" and the square part is really narrow compared to the tube>>>>>
Old 01-28-2005, 02:54 PM   #6 (permalink)
Gameroom cash: $147537
The air flow sensor is the ONLY sensor that tell the ECU how much fuel to use. You want to bypass adding fuel to the engine?
Get a 3S-GTE sensor.
BTW you found SC for 3S-GE, 3S-FE?
Old 01-28-2005, 03:18 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
Old 01-30-2005, 01:41 AM   #8 (permalink)
WRS
YO MAMA!!
yeah i'd do it, but i got an FE and it requires way more than it does w/a GE. check out that site and send an IM to the owner of the board (Jeremy) for more info. he knows a lot more about the swap than i do. BTW what engine you got?
Old 02-01-2005, 12:14 AM   #9 (permalink)
man thank you ive learned more about my ride in one than i have in the 2 years that ive owned it !!!1
Old 02-01-2005, 12:22 AM   #10 (permalink)
WRS
YO MAMA!!
so if you swapped to 5th gen ecu and wiring and all that. do you think an intake built for the 5s-fe would work in your 4th gen?
Old 02-01-2005, 08:12 AM   #11 (permalink)
maybe but does that 5sfe have that big hunk of meta(mass air sensor)at the end of the intake tube?????
Old 02-01-2005, 09:00 AM   #12 (permalink)
5S-FE is MAP. FE intake manifold won't fit GE head. You'll spend some good time playing with the wiring harness to match all the sensors.
Like I say try a 3S-GTE MAF.
