84 engine swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2005, 06:48 PM   #1 (permalink)
View GeneralBenson's Photo Gallery
84 engine swap
how difficulkt would it be to get a 3vz-e engine into my 84 celica. it's currently has a 22re, and the motor came from a 4runner, which also came with 22re's, so would fit? what kind of tranny would i need to keep it rwd? i've heard they aren't the best performing motors, but i'm building my celica strictly for drag and want more displacement, and i just got a 3vz-e where i work that only needs a new rod bearing? would this be a good idea?
GeneralBenson is offline   Reply With Quote
Old 02-06-2005, 11:03 PM   #2 (permalink)
come on, anybody? i got the v6 for free and want to know how easy it would be
Old 02-07-2005, 06:26 PM   #3 (permalink)
View surplusteve98's Photo Gallery
I have lots of toyota stuff at my yard I have never checked the bellhousings to see if they are the same I will do it tomarrow. I personaly wouldnt use a 3L v6 for anything but a boat anchor.
surplusteve98 is offline   Reply With Quote
Old 02-07-2005, 09:29 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
only a rod bearing?
Old 02-08-2005, 05:55 PM   #5 (permalink)
i think that's all that's wrong. i know it slaps like a bastard. but, i'm dubious about the performance capabilities of the 3vz-e, i may be better opff with the 22re. it'd be fun to make something fast out of that motor.
Old 02-08-2005, 06:05 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
if the bearings gone theres more bad news, you can bet
Old 02-11-2005, 07:58 PM   #7 (permalink)
BrightTundra04's Avatar
View BrightTundra04's Photo Gallery
If a bearing is gone you'll spend more to fix it than its worth unless you plan on replacing pistons w/ higher or low depending on Induction method. if it needs a new rod bearing you can bet it spun meaning you'll need a new crank "or turn the old one if Possible" new rods because of the heat caused making the rod brittle new bearings rod and mains, at this time look at cylinder walls might need to be bored over then pistons and rings will have to be replaced. Just undertook the same kind of thing w/ a 22 RE cost me about 900 total all new rotating ass. new gaskets, oil pump, machine work and lots more. if your going for high performace than you could do all this to gain displacement. Which might be just what you are looking for.
BrightTundra04 is offline   Reply With Quote
Old 02-11-2005, 11:47 PM   #8 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
A 3vz-e would probably fit but you would have to get custom motor mounts made and most likely you will need a custom hood to have enough clearance between the hood and the motor for the hood to close. If you want do to a drag motor you should look into an engine that runs more smooth then a 3vz-e though. I have seen a few 1GGTE's swapped into 3rd gens which one of those can easily be made to have a lot of power, also 7mge and 7mgte's should bolt right in and have only a little custom work for that to be in there.
Hotwheelharmer is offline   Reply With Quote
