91 celica - lurching - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2005, 07:23 PM   #1 (permalink)
View hootch's Photo Gallery
In lower gears, the car lurches. A mechanic says it might be due to a vacuum hose leak. But I doubt that that's the problem. does anyone have any suggestions?
hootch is offline   Reply With Quote
Old 02-04-2005, 09:23 PM   #2 (permalink)
View Guitarlp's Photo Gallery
Happens to the 92 ST I just purchased as well. Only bad in 1st gear, noticeable but not as bad in 2nd, and not noticable in 3-5. Not sure if it's regular as well.
Guitarlp is offline   Reply With Quote
Old 02-04-2005, 10:53 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
Well, Im regular and lurch doesnt live in my trunk Is the engine skipping?
Old 02-04-2005, 11:19 PM   #4 (permalink)
View MIGHTY's Photo Gallery
well i always thought if your in gear and your rpms reach below youe idle the car will lurch because its trying to shut down??
MIGHTY is offline   Reply With Quote
Old 02-04-2005, 11:28 PM   #5 (permalink)
When I say lurching I'm referring to driving say 8mph in first gear with my foot steady on the gas pedal. The car will lurch... kind like in a regular car if you keep taping on and off the gas pedal.
Old 02-04-2005, 11:53 PM   #6 (permalink)
OOOOOO well ur machanic could be right mine was doing that when i removed my throttle body to clean it, have you taking anything apart or adjusted anything????
Old 02-05-2005, 12:14 AM   #7 (permalink)
Nah... I'm the 2nd poster just agreeing with the first guy who took his to a mechanic. I haven't touched anything yet but I plan on doing some maintenance like running fuel system cleaner, changing fuel filter, air filter, and the spark plugs and wires (since I just bought it and I don't know when it was done last).
What did you find as the problem after removing the TB?
