Which engine do I have? 3S-FE, 3S-GE, 4A-FE, 5S-FE, 7A-FE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2005, 07:54 PM   #1 (permalink)
View 94celica94's Photo Gallery
94 Celica w/1.8 Liter. I will be replacing a headgasket and bought a Haynes manual for all the the bolt torque specs but dunno how to decipher which engine I have. I do know that it has DOHC. TIA.
94celica94 is offline   Reply With Quote
Old 02-07-2005, 09:27 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
look on the emmissions sticker on the underside of the hood, look for 7a-fe
Old 02-07-2005, 09:35 PM   #3 (permalink)
Street-Cruiser
Ostornadoe's Avatar
View Ostornadoe's Photo Gallery
^ Probably right about 7afe.
If everything seems under control, you're just not going fast enough- Mario Andretti
Its not how fast your car goes...its how much nerve the driver has to push it that fast.
Ostornadoe is offline   Reply With Quote
Old 02-07-2005, 09:41 PM   #4 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
'94 Celica ST = 7AFE
Dr Tweak is offline   Reply With Quote
Old 02-07-2005, 10:20 PM   #5 (permalink)
yes it is the 7AFE, I just looked.
Old 02-07-2005, 10:31 PM   #6 (permalink)
View anuthaCamry's Photo Gallery
um... head gaskets.... here's some comments..
clean the surfaces until they are only metal and no old gasket material
label each bolt so it goes in exactly the same place,
keep new gasket completely free of oil, grease, including chicken grease and/or any kinda oil,
clean surfaces with rubbing alcohol (let it dry for 10min though) right before you put them together
clean bolts and holes with a tap and die if possible (only one pass though), clean bolts with brake cleaner then coat with engine oil...
USE A TORQUE WRENCH
good luck!!
anuthaCamry is offline   Reply With Quote
Old 02-07-2005, 10:40 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
be very careful getting the old gasket stuff off the head, no gouges or cuts, and no scotchbrite pads on a die grinder , now the block is iron, but still be careful, i like to drag a big flat bastard across the deck to get it looking good
