ohhhhhh about your start when its cold does the rpm jump up? if not maybe its the timer for the cold start injector coming on, or lack there of
mine does the irratic idle thing where it goes up and down. ive yet to figure that out. my idle is a bit high.. once again im not sure there. check your vacuum hoses specifically the ones to your ps pump. mine never shakes too bad unless the ac is on. make sure your motor mounts are ok
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
