5sfe missing ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2005, 10:50 PM   #1 (permalink)
View canadiancelica's Photo Gallery
5sfe missing ?
WHen shes idling, seems as though there may be a miss and during low rpm accelration it seems to be lagging in power, more then ever before. It has new plugs, wies, distributor, always new oil and filter, only 217,000kms, possibilities without going to garage ?
canadiancelica is offline   Reply With Quote
Old 02-10-2005, 10:35 AM   #2 (permalink)
Gameroom cash: $147537
Maybe ignition coil. Mine was rusted to hell. Looks good from the top but all the metal plates saperated at the bottom. Hows your ground wires? EGR stuck open? Cold injector problem?
Old 02-10-2005, 11:41 AM   #3 (permalink)
Don't even know where to look for grounds, I'll have to let the coil go from the firewall for an inspection and I dont think my car has an egr, its early 91 gt, so its the 90 5sfe which, from my understanding, doesn't have an egr valve.
Old 02-10-2005, 11:49 AM   #4 (permalink)
My 90 GTS with same engine as you have EGR.
This is a disabled EGR on my Celica.
Old 02-10-2005, 11:54 AM   #5 (permalink)
Why/how is yours disabled, wouldn't that fuck shit up ?
Old 02-10-2005, 12:17 PM   #6 (permalink)
EGR recycle exhaust back to intake to lower cylinder temp to lower NO emission. I passed emission without EGR. Main thing is it'll keep intake clean without exhaust pumping back. 2 way to disable it. 1: remove the EGR valva and put a cover plate to block hole to intake. 2: remove vaccum hose that activate it, that's what you see in photo. I found out later that I got a plate blocking it already.
Old 02-10-2005, 09:16 PM   #7 (permalink)
yo mean to increase cylinder temp and to lower the emissions. I dont have to worry about emissions tests down here in newfoundland. Thanx man
Old 02-13-2005, 09:20 PM   #8 (permalink)
Can you explain this plate a little better pinapple ? Like exactlocation, maybe a pic ? thanx so much
Old 03-05-2005, 10:58 PM   #9 (permalink)
View toyguru321's Photo Gallery
had that same problem twice on my celica. i have a 1990 gt with 370,000+ miles. you may have a clogged catalytic converter or a bad converter in your car. i've had 2 replaced in mine.
toyguru321 is offline   Reply With Quote
