the celica and the supra are not the same the supra will have a 7.5" rear end and the celica will have a 6.7" most likely the same as your corolls. the 7.5" is a verry nice up grade, we run one in our circle track car and I plan on using one in our rally car project. there is a huge selection of gears available, they can handle some big Hp, and it will have disc brakes. the only celica with a 7.5" is 1985 and they have drum brakes. if you look at the spec. plate on the fire wall under the hood there is a line for the transmision and rear end after the trans coad somthing like"W58 or W52"there will be an axle coad the letter T is for a 6.7" the letter F is for a 7.5" the numbers after that are a coad for the r&p ratio. I hope this is helpful.
