Automatic tranny to Manual - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2005, 08:50 PM   #1 (permalink)
WHAT!!!!
View TeRcElIcA's Photo Gallery
Hey guys, Question... OK, if i change out the Automatic transimssion from a 1990 toyota celica to manual, do i just change out the tranny and pull out the Shifter thing? Like does that syncronizer rod thing still work on the manual tranny? uMMM get what im trying to ask here???... like the shifter, do i change that as well, when i change the tranny? thanks...
TeRcElIcA is offline   Reply With Quote
Old 02-19-2005, 03:51 PM   #2 (permalink)
WHAT!!!!
.... ok can anyone just explain how to change an automatic into a manual? things i need? thanks
Old 02-19-2005, 04:15 PM   #3 (permalink)
View virtualkuz's Photo Gallery
You need a manual transmission, the center console piece from a manual celica, the shifting linkage, and the shifter to begin with. You may also need a ECU from a manual celica. It is a lot of work that probably isn't worth it if you are just doing it to to do.
2005 Corolla XRS Silver Streak Mica
2005 Kawasaki Z750S Candy Plasma Blue
1993 Kawasaki EX500a Luminous Polaris Blue
virtualkuz is offline   Reply With Quote
Old 02-19-2005, 04:20 PM   #4 (permalink)
WHAT!!!!
I can get all this stuff from an auto dismantler. Ive done alot of work before. how difficult is it to change an auto to stick?(I'm really asking you the question) like what problems will happen really happen?
Old 02-19-2005, 04:27 PM   #5 (permalink)
Oh, i forgot all about the clutch. you'll have to get that working as well. If you are good at doing major engine work then it won't be that difficult. If it needs the manually tuned ECU and you don't change it the car will not run correctly. You are going to have to take the whole front end of the car apart. If you are comfortable doing that and have lots of time to work on it it will be mostly a problem of getting things to fit right.
Old 02-20-2005, 06:48 AM   #6 (permalink)
View EggBeater59's Photo Gallery
http://www.toyotacelicaonline.com/atomconvi.htm
EggBeater59 is offline   Reply With Quote
Old 02-20-2005, 02:06 PM   #7 (permalink)
Immortal
View Kwanza's Photo Gallery
You'll need the tranny, clutch kit, flywheel, clutch lines, clutch cylinder, clutch slave, clutch pedal, various speed sensors, shift linkages, and shifter assembly. It's a straight-foreward conversion. You install the flywheel and clutch, you install the manual tranny, the shift linkages, the shifter, plug in needed sensors and set-up the hydraulic system. I believe even the holes for the clutch cylinder are pre-drilled.
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 02-20-2005, 05:47 PM   #8 (permalink)
WHAT!!!!
WHICH MEANS MORE MONEY OUT OF MY POCKET HUH... damn it all to hell. its cool then, I found another celica that is five speed. GT-S, but the problem is the synchro or the clutch needs replacement. which when i get the car i will give you the real symptoms of the car. $2500 isnt bad right?
