stainless flex brake lines.....interest - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2005, 10:19 PM   #1 (permalink)
View canadiancelica's Photo Gallery
Anbody intersted ? 5th, 6th and 7th gens....
PM me if interested, about $70 US or $85 CDN per set of 4 made by good rich
canadiancelica is offline   Reply With Quote
Old 02-21-2005, 10:37 PM   #2 (permalink)
Lead-Foot
S92GT's Avatar
View S92GT's Photo Gallery
how hard are they to install/how do they affect the system, or are they just cosmetic? I could be interested, but would like to know about the above first.
S92GT is offline   Reply With Quote
Old 02-21-2005, 10:48 PM   #3 (permalink)
Basically replacing the rubber flex lines. They reduce brake fade majorly, I don't consider them cosmetic because they cant really be seen. Im buying them because my lines are being replaced as they are 14 years old and are unsafe. $90 CDN is much cheaper vs. $70 per line rubber ($280CDN).
THey do have a performance side with the reduction of brake fade, and I suppose they can be cosmetic if you're into that sort of thing.
Old 02-21-2005, 11:47 PM   #4 (permalink)
Gameroom cash: $147537
Originally Posted by www.EBCBrakes.com
BRAKE FADE EXPLAINED
All pads contain some organic (living) materials. Resins that bind pad compounds together are organic - petro-chemical products. As these overheat the resins revert to gas and cause the pads to “aquaplane” on a gas film which is called fade. Some pads only fade once or twice and then settle down (Green fade or bedding in fade). Other, cheaper pads suffer from continual dynamic fade, sometimes at surprisingly low temperatures.
SS brake line don't reduce brake fade. Brake fade is caused by pad overheating. No brake line will fix that. If you overheat the pad then overheat brake fluid so it boils, no brake line will help you either. Upgrade to better pad.
SS brake line reduce the spongee feel on brake padel by reducing hose expansion under pressure.
Old 02-22-2005, 10:03 AM   #5 (permalink)
Yeah, what he said, but Im not making money off this, im just going to direct interested parties to the company that sells them because i know it can be hard to find some stuff for celicas, I own a 5th gen and things are near impossible to locate.
Old 02-22-2005, 11:32 AM   #6 (permalink)
Its good price. Just made sure it come with plastic tube outside the steel wire. Flex line fail due to sand and dirt trap between thw wire and hose and slowly grind through the hose when the line moves. Get some clear PVC tube and use hose clamp to seal both ends out the flex line so nothing can get in.
