Turbo question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2005, 05:38 PM   #1 (permalink)
View Mario's Photo Gallery
Canada Turbo question
How do I know if my turbo need s to be rebuilt is there any way to check it ?. I have an 88 celica alltrac.
Thanks
Moose
Mario is offline   Reply With Quote
Old 02-24-2005, 01:46 AM   #2 (permalink)
View EggBeater59's Photo Gallery
any oil in your intake? if you are burning oil out, get a catch can. if you're still burning after that, then your turbo seals are bad. also, if you really want to know, take the turbo off the car, and spin the shaft, one hand on each side. see how much play there is. the less, the better.
1990 st-185
EggBeater59 is offline   Reply With Quote
Old 02-24-2005, 02:42 AM   #3 (permalink)
Lead-Foot
S92GT's Avatar
View S92GT's Photo Gallery
does your boost gauge behave as it always has, or is it not showing as much?
basically, why do you think it's your turbo?
S92GT is offline   Reply With Quote
Old 02-24-2005, 04:18 PM   #4 (permalink)
My boost gauge reads very little boost. I took the intake off and there is oil in the intake and play in the shaft.
Moose
Old 02-24-2005, 05:54 PM   #5 (permalink)
it is common for an older turbo (assuming yours is stock) to have a little shaft play, especially if you never had a bov/bpv. you should get a catch can, and see how much it fills. if there is a ton, then it is definately time to look at a new turbo... a rebuild will run around 300 dollars, but this would be a good excuse to get a new turbo... the ct27/tdo6 make good upgrades for gt4's
1990 st-185
Old 02-24-2005, 07:38 PM   #6 (permalink)
Search is your friend
View allblackalltrac's Photo Gallery
when your on boost does it smoke alot out the tailpipe? Thats a clear indication that your turbo seals are toast...
allblackalltrac is offline   Reply With Quote
Old 02-25-2005, 07:16 AM   #7 (permalink)
There is not a lot of smoke coming out the tailpipe.
Where is a good place to get a new turbo.
Moose
Old 02-25-2005, 10:55 PM   #8 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
www.turbocalculator.com seems to have pretty good prices...
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 02-26-2005, 09:21 AM   #9 (permalink)
Thanks for the help
Moose
