230k Seafoam OK?/ - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2005, 09:10 PM   #1 (permalink)
View mkazm83's Photo Gallery
230k Seafoam OK?/
I have a 86 Celica gt with the 2S-E motor with 230k on the clock. I dont know the history of the motor before 200k but it does burn and or leak oil. I use chevron 20-50 with a mobil 1 filter. It has Boch 4 platinum plugs. Now on to my question. is this motor safe to use Seafoam on?/ I am going to run it through my intake manifold only (not the oil). I am concerned of loosing compression. The car runs fine and I get good gas milage 25-28 mpg. Do the advantages of using seafoam outweight the potential problems it can cause?/ Anyway it can ruin my motor?/Will my car beniefit from using this product?/ Is it safe to do on a motor with this many miles?/ Ive searched the forum and have not found anyone using seafoam on a motor with this many miles. Thanks in advance
Mike
mkazm83 is offline   Reply With Quote
Old 03-03-2005, 11:24 AM   #2 (permalink)
Lead-Foot
S92GT's Avatar
View S92GT's Photo Gallery
did you try the camry forum, because they have been all about the seafoam lately...
S92GT is offline   Reply With Quote
Old 03-03-2005, 05:10 PM   #3 (permalink)
View layzienoy's Photo Gallery
it shouldnt hurt the motor
on the 240sx forums i used to go to they used ti on motors with up to 300k without problems
it has quit a few benefits for the car, and the only problems that i think it could create would be leaks created by the seaform eating away at build ups of carbon and such that formed plugs in cracks/holes, but if you think about it that might be a good thing becuase it shows you things that need to be replaced
just make sure that you put it into the right places
layzienoy is offline   Reply With Quote
Old 03-03-2005, 08:47 PM   #4 (permalink)
I have been using Lucas fuel treatment with good results, im just kind of sceptical about duing such a concentrated cleaning. Would it be a good idea to put it in through the PCV hose?/ any other places I can pour it it throught?/
Mike
Old 03-05-2005, 06:25 PM   #5 (permalink)
Well I did it last night and FUGG there was A LOT OF SMOKE. Treated it twice and it seems like I have a smoother idle now. Also pulled the plugs afterwards and I could see inside!! It looks really clean. Iwould recomend it to others.
Old 03-08-2005, 11:58 AM   #6 (permalink)
View PaulT's Photo Gallery
I've used Seafoam on my truck (91 Bronco 5.0L 160K mi.) several times. Never had a problem with it, always ran better after.
I put 1/2 can in the crankcase, 2/3 in through the brake booster vacuume line and the leftovers + 1 can into a full tank of gas (33 gal tank).
Fun watching the neighbors when you start it up after and the smoke begins
PaulT is offline   Reply With Quote
Old 03-10-2005, 11:24 PM   #7 (permalink)
View braddog0128's Photo Gallery
speaking of bosch plugs... you might want to go back to NGK plugs, thats what is best for your toyota
braddog0128 is offline   Reply With Quote
