engine swap on 1986 celica st - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2005, 07:22 PM   #1 (permalink)
View thencamearose's Photo Gallery
Question engine swap on 1986 celica st
I was wondering with if I could, and if it's worth it, drop a 22R motor in me 1986 celica st. I am basicaly wondering if the 5-speed trans in it now and the mounts will match up. If not could you guys give me info on how to up the hp or a tell me a good engine that will fit.
thencamearose is offline   Reply With Quote
Old 03-06-2005, 07:34 PM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Ummm unless you convert the car to RWD you wont get a 22R into your FWD car. The 22R is a pretty big motor for a 4 cylinder. If you want to drop something into your celica look into a 3sgte or 3sge.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 03-06-2005, 07:44 PM   #3 (permalink)
thank you, I am only 16 don't know that much yet, I was also wondering what I could do to make this a car beat alot of rice burners around my town. Oh, and can I do anything with the 2se engine in it right now.
Old 03-06-2005, 11:47 PM   #4 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Check out the options for a Celica:
www.phoenixtuning.com
Click on Toyota and then choose your car and year.
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
