Blew up my Hybrid(pics of it) - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2005, 06:33 AM   #16 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Originally Posted by Tercel GTS
Was all 8 valves hitting or just the intakes?
It was just the intake valves that were hitting. Which is odd because the cam specs were 272 .430" on the intake and 282 .444" on the exhaust side so you would think that the exhaust would be hitting before the intake but I guess the size of valves were the determinant of the valves hitting.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 03-09-2005, 08:22 AM   #17 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
you just kinda killed my plans for making a hybrid ......... well now i'll make sure to check valve clearnace if do, do this.
one question i still wonder about is can you keep the efi system in the hybrid?
^ and leaving it that way!
Old 03-09-2005, 09:06 AM   #18 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
ahhh...the carnage. Worst engine I ever roasted wasn't a toyota...it was a Yamaha warrior...the connecting rod broke loose and the piton hit the crankshaft so hard it actually cracked the piton almost all the way through..... entire new engine...FUCK.
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 03-09-2005, 11:29 AM   #19 (permalink)
SCCA Tech Services
Don't be scared about building a hybrid just make sure you clay check the piston to valve clearance and make sure you don't run to big of a cam and to make sure get your pistons cut with valve reliefs in them. As for EFI on a hybrid it can be done but you have to get the 20R head ported to match the intake manifold of the 22RE.
Brian Harmer
Old 03-09-2005, 12:42 PM   #20 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
3SGTE Time!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 03-09-2005, 01:02 PM   #21 (permalink)
SCCA Tech Services
Originally Posted by arcasmachineracing
3SGTE Time!
No I have thought it over and I am planning on just building this car for SCCA Club racing in E production class. I was going to find a 1st gen celica for it but I think I will just go with this 2nd gen. With the production class I can make it still street legal if I build it right too but we will see on that.
Brian Harmer
Old 03-09-2005, 02:12 PM   #22 (permalink)
N/A bites
Tercel GTS's Avatar
I'm thinking the timing was off a bit, maybe on the right gears, but off still. There are variable is what year head/block you mated, and then the shaving. These affect the timing as the cam is now closer to the crank. I put mine together one time(of the 10 or more times) with the timing chain off by a single tooth. I was tired from a long cold weekend and didn't double check behind myself. Bumped the key and heard a ring sound for about 4 rings, then 0 compression. Broke all 4 intake rockers, bent all 4 intake valves and created another 8 hours worth of work.
For your next R series hybrid I suggest you look into FI heads. While most have the same combustion chamber as a 22R there were a few with a really small chamber. Big valves, bigger than a 20r anyway. Much cheaper to setup. You do know there was a 22RTE also right?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-09-2005, 02:35 PM   #23 (permalink)
SCCA Tech Services
Actually the timing was not off. The problem was many things. They were Pistons with no valve reliefs in them, 20R head with small combustion chambers and head milled more then I was told, too big of a cam. With all of those that is why the valves here hitting and why what happened happened. I had an early 22R block and a 78 20R head so if I didn't have the head milled at all I should have been able to run the cam I have and not have valve reliefs. If my math was right and the machine shop had milled the head the right amount I still shold have been safe but the head was milled more and I didn't know that until after it happened. I should have been smart and clay checked it but I was too confident with my math. As for my next motor it isn't going to be a hybrid. I have decided to build this car for SCCA Club Racing in the E-production class which means I have to keep the 22R head and can only do certain things according to the rules. I do know about the 22RTE and all the info on all the 20R and 22R's that were availble.
Brian Harmer
Old 03-09-2005, 04:30 PM   #24 (permalink)
96 3MZ M/T
chronoti's Avatar
or you can go 18r-g
get that twin cam g class head!!! and stock side draft carbs ..... too bad it wasnt avaiable in america
