89 Celica Distributor Oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2005, 10:47 AM   #1 (permalink)
View pixelpadre's Photo Gallery
Well it was quite easy removing the dist. I replaced the brittle flat oring on the shaft. The new oring didnt look much bigger than the worn old one. After reassembling everything, I have more oil leaking than before. Is there supposed to be a gasket or sealant between the dist base and block? Should I run a bead of silcon around the oring to insure a snug fit?
pixelpadre is offline   Reply With Quote
Old 03-13-2005, 03:35 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
you eather pinched the ring or its the wrong one, it should be pretty snug in the head
Old 03-13-2005, 05:20 PM   #3 (permalink)
its the same diameter as the other that came out. and its not pinched. will a bead of silcon help on the o ring?
Old 03-13-2005, 05:38 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
it should be fatter, the old one is flattened out
Old 03-13-2005, 06:04 PM   #5 (permalink)
it is slightly
Old 03-13-2005, 06:09 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
it should be fatter to the point that ya about have to push it pretty good to go past the edge, thats where they like to pinch
Old 03-14-2005, 09:01 AM   #7 (permalink)
87 distributor oring
BTW in researching the cost of a new one, I found rockauto.com to be half the price of its nearest competitor.
Old 03-16-2005, 02:40 PM   #8 (permalink)
All it takes is MONEY
View marcuslogsdon's Photo Gallery
Fredk is right with the o-ring but it sounds to me like the distributor isnt seating it self correctly in the block. check, check, and recheck!!! good luck!!
marcuslogsdon is offline   Reply With Quote
Old 03-22-2005, 05:43 PM   #9 (permalink)
Thumbs up 89 Celica Distributor oil leak
REVISED EPILOG...
After replacing oring, oil is leaking more than ever. I had thoroughly cleaned around and inside of distributor so I could verify future oil leaks. Yesterday, I removed the distributor to verify integrity and and low and behold..... the inside was full of oil.
Conclusion......a second seal inside the distributor housing is shot. There are two drain holes inside presumably just for this reason. I suppose I could try to fix it but it involves pressing machine parts and I'm just not up to that. So I ordered a rebuild from rockauto dot com. With shipping it came to 172. Plus I'll get 35 back for the core.
This should finally put an end to a five year Celica nasal drip that left my calling card in every driveway I have parked in.
Removing the Distributor was simple and took a total time of less than 5 minutes including reassembly. I highly recommend anyone to take on this task to eliminate that nasty oil leak.
Any questions call me at 352.406.7103
