Different motors.. same transmission..??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2005, 01:05 PM   #1 (permalink)
All it takes is MONEY
View marcuslogsdon's Photo Gallery
Gen5 Different motors.. same transmission..???
Hey everyone. ive been thinking of doing a motor swap on my '91 celica st. right now it has the 4a-fe with about 280,000 miles HAHA!! I recently replaced my trans and was wondering if it would bolt up with either the 2.2l or the 2.0l.
marcuslogsdon is offline   Reply With Quote
Old 03-16-2005, 03:50 PM   #2 (permalink)
Gameroom cash: $147537
Nop.
You got a 4A-FE which is the A series engine. The 2.2L is 5S-FE, 2.0L is 3S-FE, 3S-GE and 3S-GTE which are all S series engine. Only same series will share tranny.
So you can swap to a 4A-GE or 4A-GZE.
Old 03-16-2005, 09:44 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
it will only bolt up to an a series block
Old 03-16-2005, 10:51 PM   #4 (permalink)
okay, thats good to know! but here is another question for ya.... as to my knowledge the 2.0 turbo was only offered in the awd model. so i would have to use a trans from the 5s-fe is that correct?
Old 03-17-2005, 01:28 PM   #5 (permalink)
Yes. It won't worth the trouble to put the AWD into any non-AWD car.
Old 03-17-2005, 02:17 PM   #6 (permalink)
so when i get the 3s-gte motor i want along with the wiring harness and ecu, does it all just plug in or am i going to have to do some wiring?
Old 03-17-2005, 02:48 PM   #7 (permalink)
6G Celi Specialist
Supersprynt's Avatar
View Supersprynt's Photo Gallery
Buy a 3sgte clip. If you dont, you'll have to source alot of parts which you will need. Including MAP sensor, AFM, solenoids, Ecu etc. etc..
If you swap to a 2nd gen 3s, you can use the S54 tranny (5s) but its kinda a crap shoot considering its stock hp is 135. You can use an MR2 tranny and conver it to FWD which is basically pretty easy. Your going to need an alltrac tranny parts (which will come with the clip) and MR2 axles. You can search google or celicatech.com for more information on this.
Supersprynt is offline   Reply With Quote
