my celica doesn't seem to start anymore. Here is what happened. I was driving home from a body shop and came to a red light, light turned green so i eased off the clutch and went to give it gas and nothing happened. The RPM's were dropping from 750 and eventually the car shut off. I went to start it engine keeps turning but won't fire. I got the car towed home and took a look at it the next day. It looks like i get gas since my spark plugs are all wet and i tested to see if i get spark which i do aswell. I'm not sure where to go from here any suggestions would be great.
little update. i chked for spark at each wire and one of them seems to be shorted. I have replaced them with an older set and still nothing. I also replaced the cap and ignition coil with one of out a working car and still nothing. Not sure what to check now.
i would check your throttle position senser and your air flow senser then, if it is all in working order swap your computer with someones that works. you may have a computer problem.... keep us updated
Mine did the same thing.What happened with mine was the idle pulley screwed up and threw the belt off a few teeth.While i put a new belt on i also took the air conditioning belt off,The car runs better and i get slightly better acceleration times and better fuel economy
