3sge Questions: Aftermarket Cam Suggestions! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2005, 12:14 AM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
4th Generation 3sge Questions: Aftermarket Cam Suggestions!
Just had a few questions about this please
A mate of mine has a st162 celica sx (GTS) with exhaust and k&n panel filter as the only mods, extractors will be on shortly and the timing on 14 degrees..
Hes wanted some cams for it for a while now..
I'm just wondering if anyone knows the duration of the cams standard and what the stock ECU should be able to cope with on standard ecu...
I believe he would have to adjust the timing higher than normal..
Someone mentioned something about having to adjust the tappets? is this hard or expensive?
Thanx for your help!
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
