GT4 & 3sgte easy mods & common faults - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2005, 01:19 PM   #1 (permalink)
Scoobie Killer
View Insanity-74's Photo Gallery
UK GT4 & 3sgte easy mods & common faults
GT4 & 3sgte quick fixes and pointers
Having been nocking around the Celica Forums for a while now, and seeing many questions repeated over and over again I thought I’d take a bit of time to produce this to help out and return the favour for all the help I have received from the sites. Focusing on GT4s (ST205`s) and 3sgte engines (standard) but I’m sure the info can be adapted to most of the 3sgte family, if not the whole Celica family.
Will start with finding Error codes (this will only work if you have the standard ECU running things).
Error codes will crop up for a number of reasons and will cover most of the cars systems, the most common error code is the code 54, coming from the Coolant level sensor on the Top mounted water to Air charge cooler (sometimes called the intercooler but this is strictly not correct terminology) also comes from problems with the water pump that circulates water around the charge cooler to the radiator (rad) on the front of the car. The sensor is prone to problems as it is sensitive and can misread a low level too easily.
To check your Error codes –
a) Do not disconnect the battery or pull the ECU fuse before doing this or you will loose all stored error codes.
b) Locate the Diagnostics port, on right hand drive cars this is on the top right corner of the engine bay as you look at it.
It is connected to a bunch of wires but is movable by undoing the clip on the inside for ease of access, but not necessary to move it.
Once you have located this diagnostics port you will need to bridge two of the connectors together marked “E1” and “TE1”, you can use a small piece of wire or a paperclip, whatever is closest to hand.
(As a side note:- when adjusting the timing on a 3sgte engine, you should connect E1 & TE1 together to get a steady reading, haven’t got a clue why, just something I have been told)
Having bridged these together you are ready to read error codes.
Return to the drivers seat and turn the key to the “On” position, this will light up the engine check light and it will start flashing.
Constant uninterrupted flashing means that there are no problems.
To find out which error code you have if any, count the flashes and pauses.
Flash, flash, flash, flash, flash, pause, flash, flash, flash, flash would indicate an error code 54
Flash, flash, pause, flash, flash, flash, flash would indicate an error code 24.
Once you error codes have been established, disconnect E1 and TE1 and return the diagnostics port to its home.
Most Error codes will effect the engine management system in such a way that it will retard the timing, and sometimes reduce boost. Retarded timings worst effect other than making the car slower is to make your fuel consumption bad.
The best way to get rid of the error 54 (it must be the level sensor and not the pump, if the pump is a fault replace it) is to bridge the sensor, you “can” replace the sensor and its not that expensive as things go, but its a lot of money for a simple sensor.
Bridging the sensor
It may not look fantastic, but I have had my charge cooler bridged for over six months now with no problems, just remember to make those regular fluid level checks. No fluid in your charge cooler is not good at all.
The next common mistake on the gt4 mostly but also on the 3sgte engine is where you tap into the vacuum line to put in a Boost gauge.
Boost gauges are a good after market mod and should be your first purchase, when you have a boost gauge, be it mechanical or electric, you will realise how slow and crap the standard boost gauge is. Incorrect boost levels are a good indication of problems with the engine and can help diagnose a lot of problems.
Most people tap into the vacuum from the inlet manifold from this vacuum line.
DON’T DO IT, this feeds info to a small transmitter which not only gives a reading for your standard boost gauge, it also supplies information to the ECU, should this line split, you gauge have a leak etc then incorrect information will be sent to your ECU and will/can cause lots of damage to your engine.
Instead a safe line to tap into would be your dump valve line or this line here for the best results
Dump valve vacuum line, good place to tap into for your boost gauge (caution needed, “can” effect the dump valve function)
Next on my list of cheap mods is to do with the Induction system, A lot of people go down the route of fitting an aftermarket kit, with a GT4 you also have to upgrade the dump valve, (standard one is fixed to the airbox) This can cost a lot of money.
I got this little lot all brand new from the internet for £120 ($200) with only a little bit a searching around.
To be honest, I would advise against a Bailey dump valve, a) they aren’t fast enough in there action and b) the suck in unfiltered air when not closed (only closed under boost)
After trying this set up for less than a week I discovered a few disappointing things, firstly the fuel economy worse than it had ever been and there was a loss of power.
So I returned to the original set up with a few mods, the first been a K&N panel filter which is great, (you still get the induction noise with it.
The second mod being the removal of the resonator box, (not sure if all models of Celica are cursed with this useless device or just the GT4?) the purpose of this is to reduce induction noise and to even out the airflow into the engine. Personally I think it’s a complete waist of space as it is just a box, with 4 very small holes to let air in, when I say small, I mean less than a mm across.
To remove the resonator box you have to remove the plastic wheel arch liner (12 screws or so) and the indicator (1 screw), there are 3 or 4 bolts holding the box in place, all pretty easy to get to (One via the hole where the indicator lives)
This is what you should pull out.
After doing this I noticed two things, more low down power, and more induction noise (YEY), worth doing this job.
Next up should be your fuel filter replacement, unbelievable difference in my car after doing this and should be well up there on your list of things to do.
It’s a bit of a bitch of a job and will take about an hour if your lucky, remove the airbox for ease of access, remove the pipes first, bolted to the filter, mine had been cross threaded by a previous owner and was a right pain in the arse to undo, next up is to remove the two bolts that hold the fuel filter to the engine bay wall. Fitting is reverse of removal. Jobs a good un!
Couple of usefull tips
Lagging the charge cooler can help prevent heat soak from heating the charge air. I used heat reflective tape and some insulating material, easy job, half hour max, removing the chargecooler can be a bit difficult. Twisting it away from both the turbo and inlet manifold is the easiest way. While your at it run some petrol through the charge cooler to get rid of any dirt and oil deposits that have built up inside. (CAUTION needed when using petrol, do it outside with a bucket of sand handy just in case)
You can just see the silver tape on the bottom of the chargecooler
ECU fuse location. Use this to reset Error codes and to reset ECU after any repair work.
For any of you wanting to install some tweeters to your front doors, inside of the door card there is a small socket already wired up and running to attach Tweeters to (thanks Mr Toyota) just about where my stubby finger is pointing, removing the door card is easy, takes about 10 mins, don’t forget there is a screw behind the door latch finger plate, and under the door grab arm.
And last but not least, if anyone ever tells you not to put the GT4 raiser blocks on your car cause you wont see anything out the back……well, make your own mind up, heres what you`ll see.
Hope that was helpful and didn’t bore you all to death.
Living the dream
Insanity-74 is offline   Reply With Quote
