coil resistance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2005, 10:56 AM   #1 (permalink)
speedyts49's Avatar
View speedyts49's Photo Gallery
coil resistance
My coil shold read from .4 to .5 ohms but It fluxuates from 0 to .8. Is this normal or could this be a sign of a shorting/going bad coil?
'08 Super White Corolla S
'96 Tacoma 5 speed 2.4
'03 Kawaski ZRX 1200
speedyts49 is offline   Reply With Quote
Old 04-02-2005, 01:38 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
0?
Old 04-02-2005, 02:36 PM   #3 (permalink)
All it takes is MONEY
View marcuslogsdon's Photo Gallery
did you test the leads to see how much resistance is in the leads themselves? usualy there is 1-2 ohms.
make sure you disconnect the high-tension wire when checking the primary side of the coil. (test the positive and negitive terminals) and yes it should be .4 - .5 ohms
check the secondary side too (check the positive terminal and the high-tension terminal) it should read 10,000 - 14,000 ohms.
marcuslogsdon is offline   Reply With Quote
Old 04-02-2005, 06:31 PM   #4 (permalink)
speedyts49's Avatar
I did not test the leads. Doesn't that factor in when using a digital multimeter?
i did disconect the high-tension wire and got a 0 to .8 ohms. IT just kept going up and down on my meter. This is what has me thinking something is wrong with the coil.
The secondary was good at 13k.
Thanks for the reply. I am going to get an aftermarket coil and at worst I'll have a spare.
Old 04-03-2005, 01:21 PM   #5 (permalink)
you might want to use a digital multimeter from now on. much more reliable for testing resistance
Old 04-03-2005, 01:43 PM   #6 (permalink)
speedyts49's Avatar
Yes thats what I have. Pretty handy tool. It was about $80 at Sears.
Old 04-04-2005, 09:54 AM   #7 (permalink)
Gameroom cash: $147537
Go to junk yard and get one long spark plug cable. You'll need one to rewire the aftermarket coil.
Old 04-04-2005, 04:18 PM   #8 (permalink)
speedyts49's Avatar
You say i'll have to rewire the aftermarket coil? We're talking about the ignition coil right?
I aslo found a water temperature sensor to not be working or at least it does not show resistance on the multimeter.
Old 04-05-2005, 01:29 PM   #9 (permalink)
93 Celica GTS
View jpdiehl's Photo Gallery
Ignition coil power and resistance
Have you tested power going to the coil? Both with the + and - leads attached and without? Coil resisstance is low on these. Primary around .6 ohms, and secondary arount 9,000 to 11,000 ohms.
jpdiehl is offline   Reply With Quote
Old 04-05-2005, 01:35 PM   #10 (permalink)
speedyts49's Avatar
I disconnected the cable from the distributor and pulled the plug connected to the coil then I did the two tests the factory manual suggested. The secondary was good but the Primary was going up and down from 0 to .8 which was weird.
I'm not sure how else to test it.
Old 04-05-2005, 10:01 PM   #11 (permalink)
well you can do a couple things. test a buddies coil and see if you get the same results. take it to the auto part store and see if they will let you test a brand new one. i wouldn't buy an aftermarket coil unless you are positive it is the coil.
Old 04-05-2005, 10:21 PM   #12 (permalink)
speedyts49's Avatar
Yeah I hoping the (one part two names-thread) is the answer once I get the part.
