Bingo. For all with the 2.2 internal ignition coil. If you experience the same problem. Take a good look at the primary and secondary resistance on the coil. ANYTHING out of range, or visual cracks in the coil, replace it. $40.00 after market Borg Warner. Fired right up with a 15 minute installation. P.S. Don't be fooled by quiet fuel pumps. Just because you don't hear it, doesn't mean it isn't working. diagnosis--check timing belt, and make sure it is spinning. Check for spark. If none found, check coil resistance, pickup resistance, and be sure you are getting power to the coil + and - terminals (CHECK IT DISCONNECTED FROM THE COIL). The ignition system is basic. Coil, pickup, igniter, and ecu. That is it. 106,000 miles on the original coil.
