Scoobie Killer
All the bits you need for a gt4 front end/hood
Bumper Parts
Cover, front bumper 52521-20200 $223.27 This is the bumper
Absorber, front bumper energy 52611-20150 $62.76 This is the foam that goes behind the bumper
Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet
retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place
Grill, sub-assy, rad., center 53101-20500 $46.29 This is the upper grille
Grill, radiator, lower 53111-20750 $125.08 This is the lower grille
Bezel, grille, lower RH 53112-20240 This is the right-hand bezel for the lower grill without fogs
Bezel, grille lower LH 53113-20180 This is the left-hand bezel for lower grill without fogs
Front turn signal, RH 81510-20750
Front turn signal, LH 81520-20750
Fog Lights and other Optional Parts
Fog lamp, RH 81210-20370
Fog lamp, LH 81220-20360
Bezel, grill lower RH 53112-20230 This is the right-hand fog light bezel
Bezel, grill lower LH 53113-20180 This is the left-hand fog light bezel
Latch, hood, LHD 53510-20510 This is the left-hand-drive GT-Four hood latch, without it, you'll have to lengthen your stock latch by about 1/2 inch.
Bracket, upper grill #1 53115-20070 $13.95 This is 1 of 2 brackets which hold in the upper grill
Bracket, upper grill #2 53118-20070 $15.46 This is the 2nd bracket for the upper grill
You can also get the reinforcment bar(your "crash-bar" or 5MPH bumper) and frame brackets, but theyre not nessicary, and the frame brackets required to use them are $180 EA from toyota. so just about everyone dont get it, they just cut down theyre crash bar with a sawzall.
Hood Parts
Hood sub-assy. 53301-20500 $444.22 This is the hood
Plate assembly, hood bulge 76190-20010 $ 42.95 This is the middle hood vent
Bulge assembly, hood 76180-20010-XX This is the hood bulge. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes.
76180-20010-F0 576, Super Bright Yellow
76180-20010-H0 752, Deep Teal Metalic
76180-20010-H1 753, Graish Turquoise M.M.
76180-20010-B0 183, Dk. Bl. Gray Me
76180-20010-G0 6M1, Dk Green Mica
76180-20010-G1 6R0, Lt Green Me.
76180-20010-A0 040, Super White 2
76180-20010-B0 199, Silver Me.
76180-20010-C0 202, Black
76180-20010-D0 3L2, Super Red
76180-20010-J0 8L5, Blue M.M. (perfect Blue)
Ornament sub assy, hood RH 75033-20030-XX This is the right-hand rear vent. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes.
75033-20030-F0 576, Super Bright Yellow
75033-20030-H0 752, Deep Teal Metalic
75033-20030-H1 753, Graish Turquoise M.M.
75033-20030-B0 183, Dk. Bl. Gray Me
75033-20030-G0 6M1, Dk Green Mica
75033-20030-G1 6R0, Lt Green Me.
75033-20030-A0 040, Super White 2
75033-20030-B0 199, Silver Me.
75033-20030-C0 202, Black
75033-20030-D0 3L2, Super Red
75033-20030-J0 8L5, Blue M.M. (perfect Blue)
Ornament sub-assy, hood LH 75034-20030-XX This is the left-hand rear vent. The -XX after the part number is a paint code, if you know your Toyota paint code, insert it there. Below are the part numbers, with color codes.
75034-20030-F0 576, Super Bright Yellow
75034-20030-H0 752, Deep Teal Metalic
75034-20030-H1 753, Graish Turquoise M.M.
75034-20030-B0 183, Dk. Bl. Gray Me
75034-20030-G0 6M1, Dk Green Mica
75034-20030-G1 6R0, Lt Green Me.
75034-20030-A0 040, Super White 2
75034-20030-B0 199, Silver Me.
75034-20030-C0 202, Black
75034-20030-D0 3L2, Super Red
75034-20030-J0 8L5, Blue M.M. (perfect Blue)
Guide,air to cowl 76191-20901 This if the optional hood spoiler
Living the dream
