code 7 pause 1 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2005, 09:30 AM   #1 (permalink)
speedyts49's Avatar
View speedyts49's Photo Gallery
code 7 pause 1
I am getting a 7 pause 1 code on the '91 celica 5s-fe which is a california egr related code.
It looks like to check the egr valve and related components you have to use the ecu and a voltmeter. The ecu is located either under the dash in the center or maybe under the console. Do I have to remove lots of parts just to get to the ecu?
I think I started getting this code after cleaning the throttle body with throttle body cleaner and was thinking maybe I just fouled something that way. The car runs fine otherwise.
Maybe I am going to have to invest in a vacuum gage and even a fuel pressure gage for another problem I have been having(hard start/engine warm).
'08 Super White Corolla S
'96 Tacoma 5 speed 2.4
'03 Kawaski ZRX 1200
speedyts49 is offline   Reply With Quote
Old 04-13-2005, 09:38 AM   #2 (permalink)
Scoobie Killer
View Insanity-74's Photo Gallery
Have you reset the ECU since cleaning the throttle body?
Living the dream
Insanity-74 is offline   Reply With Quote
Old 04-13-2005, 10:01 AM   #3 (permalink)
speedyts49's Avatar
yes I have reset it several times, everytime I try something new or mess with the components. I pull the efi fuse for about a minute and then reinsert it. the funny thing is it has come on and then later gone off, but it always comes back on again.
Old 04-13-2005, 08:04 PM   #4 (permalink)
speedyts49's Avatar
Ok i reset it everyday and it only comes back on at about the same spot on the freeway which leads me to believe that something happens when it gets to a certain temperature to cause the fault. What it is thats wrong I don't know yet.
Old 04-14-2005, 11:53 AM   #5 (permalink)
View GodFuader's Photo Gallery
Gen5
*sorry for whoring the thread :p
how do you check for codes in the Gen.5 '90. My car is hitting 15yrs now and should have some stuff wrong with it now. how do i do a random check, or do i have to wait for a 'check engine' light (might be burnt out)
GodFuader is offline   Reply With Quote
Old 04-14-2005, 04:01 PM   #6 (permalink)
speedyts49's Avatar
Your engine light should come on when you turn on the ignition before you start the car and then go out after a few seconds once you start it. If it does light at all then it may be burnt out.
Old 04-14-2005, 05:18 PM   #7 (permalink)
View ALL TRAC 88's Photo Gallery
try taking off the egr totally then clean the tube that comes from your head to the vacuum diaphram get like a pipe cleaner and some carb choke cleaner its probably just carboned up and also check the vsv for the egr its right under the center of the intake manifold
ALL TRAC 88 is offline   Reply With Quote
Old 04-14-2005, 08:21 PM   #8 (permalink)
speedyts49's Avatar
I've been looking for the VSV and by the diagrams in the book It should of been right there but thanks for the info on its location.
What I mean is the diagram in the manual shows it but it is hard to determine depth and sometimes something that appears to be in front of the engine is really behind it.
Old 04-23-2005, 05:52 PM   #9 (permalink)
speedyts49's Avatar
The light finaliy went off and stayed off which leads me to believe that it had something to do with cleaning the throttle body with TB cleaner which is when it first started.
It was coming on for a moment on the freeway and the next day even less and now not at all.
Never fails, I try and fix one thing and open a can of worms in the process.
