1988 celica GT-S specifications? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2005, 03:35 PM   #1 (permalink)
View PoR2GeEzCamry's Photo Gallery
I found a 1988 celica GT-S in my area for a great price. Im not too familiar with these generation celicas, and was wondering if anyone could give me the specifications for this car. Engine type, horsepower, etc? I really want to know if it is equiped with the 3sge? thanks
PoR2GeEzCamry is offline   Reply With Quote
Old 04-13-2005, 04:14 PM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
3SGE running 135hp samish on tq.
fun little cars, expecially with the 5spd.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 04-14-2005, 11:49 PM   #3 (permalink)
WRS
YO MAMA!!
View WRS's Photo Gallery
GT-S
Vehicle Type: Front engine, Front wheel drive, 2+2 passenger, 2 door
Sound System: Fujitsu 10 AM/FM stereo radio/cassette with graphic equalizer, 4 speakers
ENGINE
Engine Code: 3S-GE
Engine Type: Inline four, iron block, aluminum head
Bore x Stroke: 86mm x 86mm (3.39" x 3.39")
Displacement: 2.0L, 1998cc, 122 cu in.
Compression Ratio: 9.2:1
Engine Control System: Toyota Electronic with sequential port fuel injection
Emissions Control Systems: 3-way catalytic converter, feedback air:fuel ratio control, EGR
Valve Gear: Belt driven DOHC, four valves per cylinder
Horsepower: 135bhp@6000rpms (SAE net)
Torque: 125 ft-lbs@4800rpms (SAE net)
Redline: 7300rpms
DRIVETRAIN
Transmission: 5-speed manual or 3 speed automatic w/ overdrive.
Manual Specs
Final Drive Ratio: 4.18:1
First Gear: 3.29:1
Second Gear: 2.04:1
Third Gear: 1.32:1
Fourth Gear: 1.03:1
Fifth Gear: .82:1
DIMENSIONS AND CAPACITIES
Wheelbase: 99.4"
Track Front/Rear: 57.9"/56.5"
Length: 173.6"
Width: 67.3"
Height: 49.8"
Curb Weight: 2,703 lbs
Weight Distribution: 62.2%/37.8%
Oil Capacity: 4.25 Qts
Water Capacity: 7.4 Qts
Fuel Capacity: 15.9 Gallons
CHASSIS/BODY
Type: Unit Construction
Body Material: Welded steel stampings
INTERIOR
SAE VOLUME
Front Seat: 51 cu ft
Back Seat: 28 cu ft
Trunk Space: 12 Cu ft
Front Seats: Bucket
SUSPENSION
Front: Independant strut located by a control arm, coil spring, and anti-roll bar
Back: Independant strut located by 1 trailing link, and 2 lateral links, coil spring, anti-roll bar
STEERING
Type: Rack and Pinion, Power assisted
Turn lock to lock: 2.8
Turning Circle curb to curb: 35.4ft
BRAKES
Front: 9.6" x .9" vented disc brakes
Back: 10.6" x .4" disc brakes
Power Assist: Vacuum
WHEELS AND TIRES
Wheel Size: 6" X 14"
Tires: Toyo Eclipse, P205 60 R14
INTERIOR SOUND LEVEL
Idle: 47Dba
WOT: 84Dba
70mph Cruising: 73Dba
70mph Coasting: 70Dba
TEST RESULTS FROM "CAR AND DRIVER"
ACCELERATION
0-30: 2.5 secs
0-40: 4.0 secs
0-50: 5.6 secs
0-60: 8.1 secs
0-70: 10.7 secs
0-80: 14 secs
0-90: 18.9 secs
0-100: 25 secs
0-110: 37.8 secs
1/4 mile: 16 secs @85mph
Top Speed: 122mph
FUEL ECONOMY
City: 23mpg
Highway: 29mpg
all courtesy of THIS PLACE!!
If Nissan Motorsports = NISMO then wouldn't Honda Motorsports = HOMO?
WRS is offline   Reply With Quote
