Carburator glass sight leaking fuel? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2005, 12:50 AM   #1 (permalink)
View yosan's Photo Gallery
i've just acquire a 81 Celica GT 5 speed with all these option(Cruise Control, Sunroof, AC, old 8 track with EQ), its a rebuilt engine from previous owner like 2 yrs ago- Okay for the probs: I know the car needs major tune up and the Carb had many unplug vaccum hoses. I check the Carb and looked at the fuel level on sight glass and notice fuel is leaking from the glass after I ran for a bit. So what I did is messing with another carborator laying in the trash from a 4ac because it had the same glass sight and started to unscrew, pull the glass and found a seal gasket. Can I just use rtv seal so it won't leak for a lifetime?? Or do I need to replace that little gasket seal?
-Thanks
Yosan
yosan is offline   Reply With Quote
Old 04-15-2005, 06:15 AM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
-Thanks
Yosan
I think the leak is just a sign that you need to get rid of your stock carb and get a weber 32/36 or a weber 38.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
