rear wheel bearing 2000 gt-s - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2005, 02:13 PM   #1 (permalink)
View celicastorm's Photo Gallery
Question rear wheel bearing 2000 gt-s
Is this a job I should tackle on my own or let a professional replace?
Any idea how much the wheel bearing costs?
If I replace one, should I also replace the other side?
Thanks in advance for your trusted opinions...
Thank You For Your Time
celicastorm is offline   Reply With Quote
Old 11-24-2007, 01:02 AM   #2 (permalink)
g6 celica beat 99 tahoe
Zefal's Avatar
View Zefal's Photo Gallery
get an new one.. bearings are a wearing part and if you use the old one or a used one then it will have more of a chance of breaking on you... plus berings are really not that expensice for axles..
Zefal is offline   Reply With Quote
Old 11-25-2007, 12:08 PM   #3 (permalink)
Blane's Avatar
View Blane's Photo Gallery
Wheel bearings hardly ever need replacing.
I replaced a bearing in my car's front on my 1992 celica with 250,000 miles on it.
Bearing -$30
To get pep boys to press out the old and press in the new - $40
Time for me to take off hub for them to replace 3 hours.
I took off everything to get just the entire hub to take down to pep boys. I have a 12 ton press but I couldn't get the bearing out of the hub. I'd leave it for professionals.
I tried to press it out myself. Pain in the ass.
Blane is offline   Reply With Quote
Old 11-25-2007, 07:21 PM   #4 (permalink)
Den
86 Celica Gt driver
View Den's Photo Gallery
How do you tell when you need a bearing?
1993 Camry LE "5 spd" with 410k + ... still going~!
1985 Celica GT
1986 Celica GT "GONE"
Den is offline   Reply With Quote
Old 11-25-2007, 07:36 PM   #5 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
The rear wheel bearing is a pretty straightforward job, it doesn't require a press as it only comes in a unit with the hub and bearing as an assembly. Remove the wheel and brake rotor, then take out the four bolts on the back side of the hub. Remove hub & bearing, install new one.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
