Engine Light Question? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2005, 01:09 AM   #1 (permalink)
View dog0051's Photo Gallery
I went into my local mechanic's shop to have fuel system on my 2000 celica flushed. After getting the car back the check engine light came on. I took it back in they ran more tests and then had the light turned off. After starting the car a few times the light came back on. I took it back in and aksed them why it is coming on. They ran more tests and told me it was running rich and I needed to put the factory spark plugs in it. So I did, thinking it would fix the problem. After a few more starts the light came back on. I took it back and they told me that they would start charging me for the tests because everything they touched with fuel system cleaning was working correctly. They also told me that I needed to take out the K&N filter because it could be causeing the problems also. I put a factory filter in it and had the light turned off to see if it would stay off.
I just need to know if the K&N filter deposited some oil onto my Mass air flow sensor which might be causeing the problem. I say this because I called a few different toyota dealers to see if they have heard of 2000 celicas having problems with the K&N filters. I would like to know if there is a way to clean the mass air flow sensor without damaging it or if I just need to get a new one or if it sounds like it might be an O2 sensor. The code the mechanic gave me was a PO172. I would appreciate any feed back if anyone else has run into the same problem. Thanks
dog0051 is offline   Reply With Quote
Old 05-04-2005, 04:10 PM   #2 (permalink)
speedyts49's Avatar
View speedyts49's Photo Gallery
I would take out the K&N even if it did not cure the engine light problem. OEM filters are the best IMHO. I have also known a guy who had the same problem as you are having with the K&N.
It's running rich it says in my book. You just had some fuel service so something related to that should be it. Did they knock off a vacuum hose somewhere in there. I've done that and got a code that led me astray.
'08 Super White Corolla S
'96 Tacoma 5 speed 2.4
'03 Kawaski ZRX 1200
speedyts49 is offline   Reply With Quote
Old 05-04-2005, 10:05 PM   #3 (permalink)
I took out the K&N filter and cleaned the MAF. After that I disconnected the bettery for a few minutes and the loght hasn't come on since. I am also thinking about putting an intake, Header and Exhaust, but it will be a little while.
Thanks for the info. I am new around here so I appreciate you taking the time to read my thread.
Thanks, Dog0051
