ok... i've removed the timing belt... taken off the head block cover...(before all that, i removed all sparkplugs, loosen up all circuts, nuts and bolts)... i've taken the mount off to get more room and to get more access to the cam's... i've taken off one, but the other one is stuck... there's these bolts inside the block that doesn't fit any tool's i have.... i pretty much have a lot of sockets and bolts that could screw anything off except for these screws inside the head...
does anyone know if there's a certain type of ranch or socket i have to use for these inner tube in the block... how much is a head gasket, does anyone know?
thanks...
-proj celica
