can you bolt on a turbo on a 5sfe? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2005, 05:53 AM   #1 (permalink)
celicist
View Axel R DuVirage's Photo Gallery
well, can you? what are the pros (power, obviously...) and cons
Axel R DuVirage is offline   Reply With Quote
Old 05-25-2005, 05:57 AM   #2 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
a turbo 5sfe is refered to as a 5sfte...
a turbo manifold off a 3sgte (MR2 Turbo/Celica Alltrac) will bolt right up, except the 3sgte manifold has an extra space for another bolt, but you dont have to use it...
the pros are more power..
cons are you need WAY more parts than just a turbo, and it must be tuned properly, and your engine might need work, if you wanna run higher boost levels..
also LOTS AND LOTS $$$$$..
it isnt impossible, it's just not cheap..
this has been discussed MANY times before, so try useing the search function if you have any more questions, if you cant find what you're looking for during a search, then feel free topost..
just 1 example..
http://toyotanation.com/forum/t80592.html
1986.5 5-speed I/E/H/MSD '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - BHG->JDM 7MGE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 05-25-2005, 06:22 AM   #3 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
just 1 example..
Great post.
You got the "search" part in there while still leaving some info for the next guy who actually does the search!
Another great place to check for info on the "5sfte" is www.6gc.net since lots of those guys turbo them.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 05-25-2005, 09:23 AM   #4 (permalink)
celicist
thanks for the replies, thanks for the "search the forum you f&?%in' noobie" reminder
