Timing marks 3s-fe 1989
I had my water pump replaced, when i got it back I had no power.
Being the holiday weekend, the shop was already closed when I got home. I decided to pop the belt cover and take a peak. I saw that the cam sprocket was lined up with a vertical line on the cam bearing cap (while crank at 0). BUT....one inch away from that line was a nice small round shallow dot that would fall directly under the hole on my cam sprocket. So which is it? My chiltion book shows no lines just holes. But heres the catch. That nice little shallow hole on the cam bearing cap, is not located straight up at 12 oclock on the block. I think its more like 10 oclock.
I loosened the belt and put a wrench on the cam and turned it while maintaining the crank at zero until the two holes lined up perfectly (the teeth jumped the belt grooves as i turned it, making a loud snap sound eact time). I havent done anything more than that. I am afraid to start it, because I dont know if I could damage valve stems. I was assuming that the crank at zero was with #1 at TDC but I really dont know if it was or if I was out one revolution.
Can anyone help me?
