If your car is standard then the jacking points on your car should be the same height, if you have upgraded suspension then usually the front `drop` is more than the rear so the back will sit higher, make sure you have a full tank of gas and nothing stored in your car that could effect the balance before measuring again.
Internally busted dampers should have no effect on the ride height of your car as they have no effect on that, they will stay where you put them ie have no springs inside. check that your springs are located correctly and have no overlap on their locating points (if it has them) and make sure the springs arnt broken. (they can snap sometimes but very rare these days). Have a jump up and down in the trunk, maybre the car just has to re-settle after you`ve worked on it, if its still the same in a week or two then I`d look into it further.
Living the dream
