Only do a 3SGE if you're prepared to do the whole swap and wiring deal. If you can't do it yourself... or don't know anyone with Toyota wiring experience to help you out, I wouldn't reccomend trying to do a Toyota engine swap until you've gained enough experience and have done enough research on Toyota wiring. Toyota wiring is a whole nother beast from other makes... so do your research if that's what you want.
Aside from that, I'd just do a replacement. Usually "remanufactured" or "rebuilt" motors are costly... as much as the car's worth sometimes. Most people just go with used low-mileage replacements, which can be found much cheaper. Used 5SFE's usually run around 500-1000 dollars depending on the place you're buying from and what year/mileage the engine is. There are several different versions, but they should all directly swap with the proper revision manifolds. Good luck hmong brotha....
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
