Engine Swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2005, 04:49 PM   #1 (permalink)
View Jamie Moore's Photo Gallery
USA Engine Swap
I have 92 Celica ST (st180) with 4afe 1.6L And want to swap it with - 5sfe from 92 Celica GT (st184).I have the complete car & engine (GT). What will i have to do to make it possible.
Jamie Moore is offline   Reply With Quote
Old 06-09-2005, 07:42 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
your better off making the gt celica driveable with parts from the st if possible
Old 06-09-2005, 09:46 PM   #3 (permalink)
All it takes is MONEY
View marcuslogsdon's Photo Gallery
fredk is right..... the ST is the corolla front end.... the 5sfe engine will not bolt up.... you are better off building the GT.
marcuslogsdon is offline   Reply With Quote
Old 06-09-2005, 09:52 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
we call the celica st a corollica
Old 06-09-2005, 11:16 PM   #5 (permalink)
Gameroom cash: $147537
I agree. Sell the ST to fund the GT. Better, get a GTS.
Old 06-14-2005, 06:40 PM   #6 (permalink)
View celfatic's Photo Gallery
Well, first of all, you will need the braket (passenger side) that holds the motor mound from a gts and weld it on the same exact place the gts has it. Then YOu will also need all gts motor mounts. After that you will need the engine of course and the gts tranny as well. You will also need the gts computer, and have someone to wire it, gts axles, and last but not least, you will need the two front brake assembly so the axles can fit.(now you will have the 5 lug conversion) Therefore, your looking into spending some cash. You probably are better off to getingt a gts cuz its the easier way to go and it will save you cash as well. I would go 3sgte on the st cuz its lighter and youll get heads turning from the gts;s trying to punk you.
celfatic is offline   Reply With Quote
Old 06-14-2005, 09:17 PM   #7 (permalink)
camrys blow off too!
View silverstreakin's Photo Gallery
or spend the cash on a 4agze. that would be pretty interesting
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
silverstreakin is offline   Reply With Quote
Old 06-15-2005, 10:48 AM   #8 (permalink)
remember that the ST isnt designed for a motor over 150hp. you should be carful what motor you decide to put in. even if it is the 4a-gze you may want to consider some reinforcing in the engine compartment and make sure you choose the right tranz.
Old 06-28-2005, 08:27 PM   #9 (permalink)
where can i find a -4agze- that will come with computer,wire harness and correct tranny
Old 06-28-2005, 11:48 PM   #10 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
www.venus-auto.com tell them that Dr Tweak from Phoenix Tuning sent you. And you don't need to reinforce the engine bay at all. A brake upgrade is always a good idea (use stock GT or GTS parts). And you can also swap in the 3SGTE but it's more work.
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 06-29-2005, 01:56 AM   #11 (permalink)
Thanks Dr Tweak will be contacting them about there 4AGZE(Supercharger)
Old 06-29-2005, 05:57 PM   #12 (permalink)
View EggBeater59's Photo Gallery
what else did the 4a come in besides the mk1 mr2
1990 st-185
EggBeater59 is offline   Reply With Quote
Old 06-30-2005, 01:31 AM   #13 (permalink)
where can i find the complete swap info on what i need to do
Old 06-30-2005, 02:05 PM   #14 (permalink)
4A-FE come in Corolla, 4A-GE in GTS.
4A-GZE come in JDM Corolla Levin.
Old 06-30-2005, 08:20 PM   #15 (permalink)
You will need to cut the bracket that holds the gts motor mount in place from the passenger side. Then after cutting it off the gts, you will need to place it in the same exact place on the st) as the gts had it. (it will be best to check if their both in the same place) Then you will need a welder to weld the motor mound bracket to your body. After this, you will need to use the motor mounts from the gts. Wiring it won't be to hard, you will just take off the wire harness and ecu from the st and replace it with the gts. Its just plug and play. Oh, you wiil also need to use the gts gear linkages. One more thing a problem you might encounter is that you might have to convert the st into a 5 lug so the axles fit right in. The exhaust well, use the gts because im pretty sure it fits.
Have any qst. e-mail me at o.pineda@sbcglobal.net
