5sfte dyno results! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2005, 10:30 AM   #1 (permalink)
View presure2's Photo Gallery
5sfte dyno results!
hey guys, hardly ever post here, but figured you'd all like to see this.
i finally finished up installing my 5sfte setup last week, and made it do the dyno yesterday.
things went really well, now i just need bigger injectors. lol
the basic setup consists of:
94 celica GT with a 98 5sfe
ATS ct-27 46 trim
3"dp & exhaust with magnaflow race muffler
315cc injectors
SAFCII
MSD BTM to be installed in the next couple days
heres a link to a compilation i made of a few of the runs:
http://s47.yousendit.com/d.aspx?id=0...O0Q5BS4ZNYIASL
heres the dyno file
www.6gc.net for all things 94-99 celica related
http://www.6gc.net/members/presure2 for more info on my car
presure2 is offline   Reply With Quote
Old 06-12-2005, 12:01 PM   #2 (permalink)
Reppin my Home
troy's Avatar
View troy's Photo Gallery
stock heads and bottom end?
not sure if you should be boosting a 5sfe very high if its not rebuilt :\
troy is offline   Reply With Quote
Old 06-12-2005, 12:14 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
That's leaner than I would want considering all the camry 5s-fte's that have melted pistons or rings due to mechanical, or tuner error.
<enters water injection> I'll save you!
Awsome job tho. I bet that little celica can move out now!
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-13-2005, 04:27 PM   #4 (permalink)
camrys blow off too!
View silverstreakin's Photo Gallery
yeah hopefully a huge ass fuel pump too. im with toysrme be careful unless you are running the stock wastegate. and maybe make midrange a bit richer.
water injection i like this guy!
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
silverstreakin is offline   Reply With Quote
Old 06-13-2005, 04:37 PM   #5 (permalink)
guys, ithing you have the wrong impression. this is not your avarage "throw some parts at the engine and hope it works" setup. we're talking new turbo, manifold dp injectors the whole 9
ALL stainless lines, egt gauge, oil pressure, 26x6x3 bar & plate intercooler..its all there..
running about 8psi, creeps up to about 9 in the high rpms without a HINT of detonation, with good egt's
this is also a '98 block, metal headgasket, under 60k
as far as the fuel curve, it is a "bit" lean in the low end, but that will be taken care of soon, new, bigger injectors are on the way, im pretty much maxing out the 315cc supra injectors right now.
anymore naysayers??
hahaha you guys are funny shit.
Old 06-13-2005, 09:13 PM   #6 (permalink)
have you guys ever seen a stock 5s dyno sheet? it runs pretty damn lean already...after 3500rpm, its actually much richer than stock.
as far as 7psi is concerned, i think you guys also keep missing the fact that this is a 98 block, with a stock metal headgasket, also has more webbing than the earlier blocks. god, cant wait too see what you all have to say when i come back with the new injectors and 225whp!
Old 06-13-2005, 09:19 PM   #7 (permalink)
Boooost
turbo_GT's Avatar
View turbo_GT's Photo Gallery
those number aren't bad at all..good job..
Your signature is in violation of rule #4.
http://www.toyotanation.com/forum/t20118.html
turbo_GT is offline   Reply With Quote
Old 06-13-2005, 09:27 PM   #8 (permalink)
Toysrme's Avatar
I really like what youve done. I'm not a naysayer, nor do I think I had the wrong impression.
Just trying to give some free advise (You know free advise is the worst kind right!? )
No, I don't think I had the wrong impression. 12.5-1 A/F most of the time on boost. I'd be fine running that with water injection, but I'd have that bitch in the 11's for safety without it. I'm not a pussy, I'm smart!
If you've got forged pistons, and new, bitchen rings, that's great. Probably wouldn't hurt that engine for a long long time, or some over the top abusive driving.
Why water injection? I wrote a thing about it in the camry forum a few weeks back.
In a nutshell, NACA found way back in the day that they could make more power without knocking at a 15-1 A/F ratio, and substituting 20% of fuel for water then they could at a straight 10-1 A/F ratio. Water, or water/ethanol injection adds a margin of error against lean-outs that is nearly incomprehencible till you see the data!
Seriously, I wasn't trying to bash your car man. I just don't want you to have turbo boost in your crankcase.
Now with Turbo!
Old 06-13-2005, 10:12 PM   #9 (permalink)
same here, im definately not a naysayer. good work. but someone back me up on this one, webbing on the block doesnt do crap for your rods and pistons. i would have went with the 93 block for the forged stock internals. although im not sure of the 98's either.
running lean on a stock engine is fine...when you run lean with 7psi on it...thats a different world together. do some searches man...weve had quite a few casualities in the 5s world. dont neglict your fuel pump either man. (i dont know if you have one)
either way, awesome job keep us up to date
Old 06-14-2005, 05:55 AM   #10 (permalink)
222gph walboro pump...pleanty of fuel to the rail.
11:1?
thats not safe, thats a waste.
in a turbo car you really want a 12.5 or so to 1 ratio.
guys, head over to www.celicatech.com in the 6gc forum. and read my writeup and whats involved in my setup
a 93 block, over a 98? are you nuts??
Old 06-14-2005, 09:29 PM   #11 (permalink)
blocks dont mean shit to me bro internals do. 93s came stock with a forged crank and rods. that makes a big difference. little extra webbing on a block? its an open deck. give me forged internals!
Old 06-15-2005, 12:18 AM   #12 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Why buy a CT27??? 200whp could have easily been attained without spending $1,000 on a upgraded CT26.
Old 06-15-2005, 08:53 PM   #13 (permalink)
ishcoleoboWhy buy a CT27??? 200whp could have easily been attained without spending $1,000 on a upgraded CT26.
not @ 8-9lbs.
btw, what makes you think the 98 DONT have forged internals? lmao
Old 06-15-2005, 09:12 PM   #14 (permalink)
Peter's Avatar
View Peter's Photo Gallery
u need to feed that engine more fuel, its running lean........what fuel pump are u looking at
Peter is offline   Reply With Quote
Old 06-16-2005, 05:51 AM   #15 (permalink)
peter, you need to READ the posts. i KNOW im lean, im maxing out the injectors on that run. i need bigger injectors.
the walbro 225gph pump is in, PLEANTY of fuel to the rail.
