need help 89 celica problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2005, 11:58 PM   #1 (permalink)
need help
View dean p's Photo Gallery
Canada need help 89 celica problems
I was just about to sell my car when I thought, gee I should wash the engine compartment. This was the biggest mistake. For some reason now my car does not want to start that well. After about a 1/2 hour when I finally get it going, it will idle nice, but when you apply the gas fast it wants to stall; however, when I slowly apply the gas it will rev up fine. I have checked the dis cap, plugs and wires, cleaned the fuel injector, cleaned all inside the butterfly value (located just after the air intake) changed the oil. I am at a loss as what else it could be. Has anyone had similar issues before?
dean p is offline   Reply With Quote
Old 06-16-2005, 12:43 AM   #2 (permalink)
WRS
YO MAMA!!
View WRS's Photo Gallery
you didn't happen to get water in your fuse box did you?
If Nissan Motorsports = NISMO then wouldn't Honda Motorsports = HOMO?
WRS is offline   Reply With Quote
Old 06-16-2005, 01:55 AM   #3 (permalink)
View EggBeater59's Photo Gallery
wasn't any water in the dizzy cap when you checked it?
1990 st-185
EggBeater59 is offline   Reply With Quote
Old 06-17-2005, 03:02 PM   #4 (permalink)
farqy
View farqy's Photo Gallery
evap container
may be the evaporative canister
when you rev it, your engine draws the fuel from there to expend that fuel, and if it was full of water, it would idle just fine on fuel from the gas tank, but then when you pin it, you would be drawing water from the evap container and wreaking havoc
try taking off the hoses from the evap container and just stoppering them, pinch em' off or whatever, then run it....
just a suggestion
farqy is offline   Reply With Quote
Old 06-17-2005, 04:33 PM   #5 (permalink)
Gameroom cash: $147537
Water in spark plug well causing miss fire. Blow, suck all the water out.
Old 06-17-2005, 05:27 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
get it warmed up and pull the plug wires out of the head and the dist cap off, let all the water dry up and reassemble
Old 06-21-2005, 10:30 PM   #7 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
also check your AFM. water or moisture in th AFM will cause a malfunction in the AFM. maybe you should leave your car outside on a hot day
89CelicaGTTurbo is offline   Reply With Quote
Old 06-23-2005, 01:07 AM   #8 (permalink)
Just Drift
View 82 RA64's Photo Gallery
Comperssion check?
82 RA64 is offline   Reply With Quote
Old 06-23-2005, 06:39 PM   #9 (permalink)
doesn't sound like an afm to me.. ususally car won't idle at all. but, have you checked for error codes from the ecu yet? that would help you... alot.
1990 st-185
Old 06-24-2005, 10:37 PM   #10 (permalink)
need help
still trying
Well I still have not been able to make any progress in making the car run smoothly or starting easier. The compression is good and the evaporative canister is good as well. Wouldn't the spark plugs be wet if I was trying to start it for awhile? I noticed that they are dry when I pull them out, they are somewhat carboned up most likely to the turning over process. I am thinking it might be something to do with the injectors, suggestions? I really don't want to spend alot of cash just to sell it, but what can I do.
Old 06-29-2005, 01:20 PM   #11 (permalink)
Like EggBeater59 said. check for any error codes. if nothing comes up then it could be something mechanical. if a code pops up, you should get a good idea of what sensor need to be replaced or fixed.
Old 07-04-2005, 10:49 PM   #12 (permalink)
old fart
View el niño's Photo Gallery
check the spark plug rubber caps, any water down in there will short it out and make it run like crap.
does keeping your foot down count as forced induction?
el niño is offline   Reply With Quote
Old 07-04-2005, 10:52 PM   #13 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
plugs are dry after cranking?
Old 07-06-2005, 10:11 PM   #14 (permalink)
old fart
the wire rubber cap connectors that go over the plugs, not under
Old 07-06-2005, 11:37 PM   #15 (permalink)
need help
Thanks for all your suggestions. It ended up being a cracked rotor in the distributor. I looked at it earlier and couldn't fine anything wrong. After spending a few bucks to get it diagnosed all it needed was an $11.00 part go figure.
