might be getting a 2nd gen? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2005, 12:22 AM   #1 (permalink)
View foompla's Photo Gallery
I was seriously looking at getting an old school toyota pickup as a second car (to have as a parts hauler for my chevy hehe). I wanted a pickup particularly because it had the 22-r motor in it.
hhooowweeevvveerrr... an '81 celica mightve just fallen in my lap. so, this might be someone tapping me on the shoulder. my question to you guys is: What kind of mods do you guys do to the carb for big power. Id assume there are rebuild kits with bigger jets and rods etc?
I saw somewhere else that the celica came with a couple of carb options, asain, weber etc. This is an st, so should i assume its an asain? what are my options for the carb?
any manifolds that would bolt up for a turbo?
foompla is offline   Reply With Quote
Old 06-23-2005, 01:06 AM   #2 (permalink)
Just Drift
View 82 RA64's Photo Gallery
An ST model is i believe just like the economy low power version. But if youve got the extra cash throw a 1g-gte in there. Now thats an engine.
82 RA64 is offline   Reply With Quote
Old 06-23-2005, 05:02 PM   #3 (permalink)
yes, id be building a motor for it. my main concern was if the carb would be of any use - apparently its not.
Old 06-24-2005, 12:21 PM   #4 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Yeah if you want to build your motor up get rid of the nasty stock 325 CFM asian carb. If yo want to stick with a downdraft your best bet is a weber 38 outlaw carb. If you want some real poewr out of your carbs go with twin sidedrafts. When I had my 81 celica GT I built a 20R/22R hybrid and I had twin weber 40mm sidedrafts on it and that baby had a ton of low end power.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 06-24-2005, 01:22 PM   #5 (permalink)
Just Drift
How much does that usually go for? Yeah the 22r sound mean, but its really not lol.
Old 06-24-2005, 01:27 PM   #6 (permalink)
SCCA Tech Services
well I pieced my sidedraft carb setup together and so it only cost me abot 400 bucks but I doubt anyone can do that unless they get as lucky as me. Most new setups cost about 1400 but if you shop around on ebay you can probably pick up a set for about 800 bucks. As for the 22R it is a mean motor but not in stock form. If you build it up you can make some pretty good power out of it though. Also in my last reply I forgot to tell you that there was a turbo version of the 22R which came in the 85-87 trucks and 4 runners. They are very rare but you can still get an exhaust manifold from it brand new from toyota and then bolt up a CT26 turbo and run your lines and what not and bam you have a turbo.It is a little harder to do then I put it but you get the idea.
Brian Harmer
Old 06-25-2005, 12:29 AM   #7 (permalink)
those were diesels? great info tho. thankyou very much.
Old 06-25-2005, 12:47 AM   #8 (permalink)
Just Drift
Hmmm, my celica, turboed. Dont make me cream my panties now... I actualy found pace setter headers, yeah pace setter headers for my car, thinking of that...
Old 06-25-2005, 09:09 AM   #9 (permalink)
SCCA Tech Services
No they were not diesels they were gasoline engines. All 22R engines were gasoline engines.
Brian Harmer
Old 06-25-2005, 09:10 AM   #10 (permalink)
SCCA Tech Services
Pace setter is a piece of crap. What you need to do is look around on ebay for a doug thorley header. Those are the best flowing headers you can get for a 22R. Also if you want to find things for your 22R go to www.lcengineering.com All they do is make things for 22R's and tacoma 4 cylinders. You will find anything you want there.
Brian Harmer
