Motor Swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2005, 07:53 AM   #1 (permalink)
View rppta's Photo Gallery
Question Motor Swap
I have a 91 Celica GT with 2.2 that son wrecked. Found a 92 Celica GT that needs motor. Does anyone see problem with swap? Any known problems with ecu compatability? Thanks for help!
rppta is offline   Reply With Quote
Old 06-27-2005, 08:47 AM   #2 (permalink)
View locker's Photo Gallery
91 and 92's are very different wiring harness and ECU's. If you pull the motor wiring harness and ECU out of the 91 you'll be fine. The other option is to swap short blocks. IE Pull both motors and take everything off the 92 and bolt it to the 91 short block to avoid the wiring issue
locker is offline   Reply With Quote
Old 06-27-2005, 09:50 AM   #3 (permalink)
Gameroom cash: $147537
Yes only use the block and head from 91 engine. You'll need the knock senosr from the 92 block also. Keep intake manifold and all electronic from the 92.
Basic differents: Intake manifold, throttle sensor, distrubutor, cold injector, knock sensor.
