Brake Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2005, 09:40 AM   #1 (permalink)
View Sleeeka's Photo Gallery
Brake Lights
My rear lights work, reverse lights and indicators. Just the brake lights dont work when i press down...
Ive checked all the bulbs and all the fuses and still nothing.
Can anyone help ?
whos your daddy ?
89 Celica St162 White Lightning
3s-ge 2.0L
Sleeeka is offline   Reply With Quote
Old 07-03-2005, 10:02 PM   #2 (permalink)
old fart
View el niño's Photo Gallery
brake switch by the pedal.
does keeping your foot down count as forced induction?
el niño is offline   Reply With Quote
Old 07-04-2005, 06:21 AM   #3 (permalink)
yeah man i checked that and it works..
whos your daddy ?
3s-ge 2.0L
Old 07-04-2005, 06:44 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273421
View REN69's Photo Gallery
How do you know the pedal switch works if the lights don't go on when you press the pedal?
Old 07-04-2005, 09:55 AM   #5 (permalink)
Ricer Hunter
View flex-appeal's Photo Gallery
heard of a thing called a multimeter?
flex-appeal is offline   Reply With Quote
Old 07-04-2005, 10:47 AM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
It can be a faulty turn signal switch, but it'd be the first one I ever heard of going bad on a toyota.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 07-04-2005, 01:42 PM   #7 (permalink)
Ricer Hunter
considering the brake lights are the problem, I really doubt that the turn signal switch is where he should be looking - toyota or otherwise
Old 07-05-2005, 01:36 PM   #8 (permalink)
farqy
View farqy's Photo Gallery
i had a problem with my brake lights that when I hit the brakes, all the rear lights would go out... but the tail lights would work otherwise... i had a bad ground somewhere in my pigtails, so I replace all four of them, and now they work just fine... for now...
lots of wire splicing though
farqy is offline   Reply With Quote
Old 07-06-2005, 01:28 AM   #9 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
Check your ground connection point and fuses first!
Rick89GTS is offline   Reply With Quote
Old 07-07-2005, 05:54 AM   #10 (permalink)
yeah i fixed it now, i cut the wire at the backend
connected it upto my old speaker wire and re routed it at the front end into the switch directly
and bam! Ive got working break lights once again!
whos your daddy ?
3s-ge 2.0L
Old 07-07-2005, 06:30 AM   #11 (permalink)
N/A bites
Tercel GTS's Avatar
If on a car with yellow turns this is correct. However he didn't say the problem was on the celica. On American cars and any others that share a bulb with brake lights and turn signals the turn switch interupts the brake signal to allow the bulb to flash. It is actually a common repair.
雄のハヤブサ
