6Gen Celica ST 94' 3sgte swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-09-2005, 03:52 AM   #1 (permalink)
View 10seccelica's Photo Gallery
Smile 6Gen Celica ST 94' 3sgte swap
OK so i bought this car off ebay for 2grand, its got 80k miles, nice interior shitty seats, came from miami, FL. I got it with an unfinished 3sgte swap, heres what i got then ill list what i know im missing. I got shift linkage and shifter in place in the car, I got the clutch master cylinder and the holes tapped for it, i also have the bracket that holds the clutch pedal (this car was an auto) I need to find the clutch pedal assembly and hydraulic lines. I got the motor with the all-trac tranny and it arrived in the car by only the driver and passenger side motor mounts (bad weld jobs too i need to redo them) so its the AWD tranny with the transfer case removed and a blocking plate installed (i heard rumors I loose power this way? if so i will get an Mr2 tranny in its place) now i have one new axle for the alltrac tranny but only the one so if i keep the alltrac setup i need the second and if i go mr2 i need a new set. Also i need diagrams and a place to buy the wire harness for my car. Also I need a radiator since the bottom hose for my car was on the opposite side of the 3sgte, so will an alltrac or gt-4 radiator work? Thats all I can come up with for now im really tired. Any help is appreciated, I need this car asap.
10seccelica is offline   Reply With Quote
Old 07-10-2005, 06:38 AM   #2 (permalink)
View presure2's Photo Gallery
you need to pull that engine and start over, the tranny wont work in the 6gc. you need a mr2, or celica(FWD) traz..head over to 6gc about the car, we can help alot more over there as its 6th gen specific.
www.6gc.net for all things 94-99 celica related
http://www.6gc.net/members/presure2 for more info on my car
presure2 is offline   Reply With Quote
