ok i just found out some information, but i dont know if it's good or bad.. apparently i cannot bolt up a 3sfe block to my 3sge head/components, but what i need to know is this... can i fit 3sge pistons into a 3sfe block and make it work that way? and if i can, is that the only problem i have to worry about.. it would cost like 200 dollars for a crankshaft for this thing and with the price of used engines out there it's looking like i might end up letting the thing set until i can just get an engine for it instead.. it would be nice if i could find a used 3sge block with all of the internals since that's all i need, but i think that most people are usually looking to sell the whole engine. here is the info that i found out, from it i can tell that i probably cannot use this block on my head..
Although the block appears identical, the bolt pattern is definitely the same, the heads have a different configuration. In the 3SFE, the combustion chamber is partially in the piston crown, whereas in the 3SGE, the pistons are flat topped with valve reliefs, and the combustion chamber is totally in the head. This would prevent the fitting of a 3SGE (higher flowing) head onto a 3SFE block, without changing the pistons. The compression ratio would be too low to be satisfactory, and would counteract any gains in flow. It is not known if a compression increase in a 3SFE could be achieved by using 3SGE pistons. The resulting compression gain might be too high to run on readily obtainable fuels. The piston pin fitting is different, also.
The cambelt crankshaft pulley tooth pitch has been checked and is the same on the 3SGE & 3SFE, but different on the 2s engine.
The 3SFE and 3SGE crank/rods are different, despite the same stroke. The 3SGE piston pins are fully floating, whereas the 3SFE are press fit.
The actual block on both engines appears to be identical, and therefore interchangeable.
Piston configuration is different between F and G heads
compression ratio will be unknown, potential valve interference
the timing components for the G head are different
