remove the tires, remove the cotter pin on the drive shaft and the one on the tie rod, bang out the tie rod from the spindle, remove the large 30mm bolt on the shaft, remove the 3 bolts holding the lower ball joint to the spindle, pry the lower control arm down and pop the lower ball joint out from the control arm, swing out the whole strut/splindle assembly and bang the drive shaft out of the hub. *NOTE: do not put the wheel back on the hub or have the weight of the car on the hub assembly without the drive shaft torqued in place or you will wreck the wheel bearings!*
