Bucking Celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2005, 12:11 PM   #1 (permalink)
Toyota Newby
View CelicaGT5's Photo Gallery
Bucking Celica
HI,
I have this recent problem with my 1988 celica gt. It has a 3s-fe engine with 160 K on it and a manual trani as well. Not always, but most often the car bucks when I put it into gear normally. It drives like I just learned how to drive stick. However, this is not the case. The bucking can be overrided by pushing in the clutch slightly and easing it into gear a second time. The car does not buck if you floor it, just when you drive norlmally. Please help.
CelicaGT5 is offline   Reply With Quote
Old 08-05-2005, 04:57 PM   #2 (permalink)
speedyts49's Avatar
View speedyts49's Photo Gallery
I recently had the same thing happen and it turned out to be a bad oxygen sensor and map sensor or so I was told. Got a map sensor at the salvage yard. It could be a vaccum leak or a tranny related issue such as low or no gear oil.
'08 Super White Corolla S
'96 Tacoma 5 speed 2.4
'03 Kawaski ZRX 1200
speedyts49 is offline   Reply With Quote
Old 08-07-2005, 05:51 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
check the big intake hose between the mass air and the manifold for air leaks and cracks
