» Site Navigation
» Buyers Guide
» Network Links
Celica Forum
Forum for all Toyota Celica discussion! Including the ST16x/18x/20x, and ZZT230/231.
09-24-2002, 07:22 PM
#1 (permalink )
88 Celica GT or GTS
Ok, I know someone should be able to answer this.
How can you tell the difference from an 88 Celica GT and an 88 GTS. ie. it has been debaged, spoiler may be an add on, etc.
is there a code on the engine that says 3SGE somethere on the gts vs the 3SFE on the gt...
What were the differences in the models anyways??
thanks.....
09-29-2002, 11:15 AM
#2 (permalink )
GT is 3SFE i believe single cam. GTS is 3SGE for sure dual cam. otherwise just buy an all-trac
10-04-2002, 02:55 AM
#3 (permalink )
3s-gte in a Camry?!?
The 3s-fe is a twin cam engine. Very similar to the 3s-ge. Sorry, just had to take exception to that 'cause that's my engine.
-Charlie
10-04-2002, 09:43 AM
#4 (permalink )
White 90DX is right.
10-04-2002, 10:21 AM
#5 (permalink )
so its a dual overhead cam with single cam gear?
GTfOURdREAMS
1988 Toyota Celica Alltrac (st165)
1985 Toyota Corolla GTS Coupe (AE86)
10-04-2002, 11:45 AM
#6 (permalink )
Correct. The second cam is driven directly from the first, like most Toyota engines.
-Charlie
10-04-2002, 12:26 PM
#7 (permalink )
Yep, scissor gear.
10-25-2002, 04:46 PM
#8 (permalink )
How to tell the difference
GT and ST models had 4 bolt rim patterns while the GTS had a 5 bolt pattern....thats the best way to determine it.
10-31-2002, 02:49 PM
#9 (permalink )
the power difference, is the 3S-GE made about 150 bhp whereas the 3S-FE made 115.
Of course the main difference is in the head, as denoted GE & FE. Think of the GE as the performance head designed for higher flow and the FE is optimized for fuel economy and low to midrange power.
I believe the 3S-GE also had the TVIS dual-length intake runner.
tan
-Retired: 88 Camry V6 5-speed & 84 Corolla Sedan
-Now driving 02 Golf TDI (hey I got a 80 mile commute)
10-31-2002, 03:24 PM
#10 (permalink )
Its 135 for the 3SGE and 115 for the 3SFE, and it did have TVIS for that run.
11-01-2002, 06:51 AM
#11 (permalink )
that's right...the newer 3S-GE had 150.
tan
11-01-2002, 08:55 AM
#12 (permalink )
No, the newest 3SGE had 215is HP, thats the BEAMS, the one before had 156 and the one before that had 135.
11-01-2002, 09:04 AM
#13 (permalink )
the dual vvt-i is Altezza only (200 to 210, depending on transmission).
The Caldina, MR2, & Celicas had the non-VVT-i 3S-GE, in Japan of course.
tan
11-01-2002, 09:48 AM
#14 (permalink )
thats right, but the 3SGE in the 4th gen Celi only put down 135HP, which really isn't that bad seeing as how the 5SFE puts out the same numbers but has 0.2 more L of displacement.
btw, welcome to the board, good to have some people that are knowledgable here.
11-01-2002, 10:33 AM
#15 (permalink )
fifth & 6th put out about 150 bhp.
the 5S, due to its slightly larger displacement its F head made a broader powerband
tan
Linear Mode
