On the 5th gen the pump was located below the fluid container, you would have to remove the fender liner to get access to it.
Before replacing the pump make sure the ejector holes are not clogged with dirt, you can clear then with a pin and that the pump is getting power (you can hear the pump whirr when pressing the button)
Part number would be: 85330-12280 MOTOR AND PUMP ASSY, WINDSHIELD WASHER
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
